July 03, 2025, 12:55:34 AM *
Pages: 1 ... 12 13 [14] 15 16 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 194678 times)
« Reply #260 on: July 24, 2019, 07:06:05 AM »
Nice, Great post so far.
Wayne b
camxsmith
« Reply #261 on: July 25, 2019, 09:31:32 AM »
Well tanks back,, Reg did a good job.  $160 to weld in new location. This should now be closer to the back of the passenger side inner mud guard. Hope to have the filler in the same location as a wagon or ute.
Looks patchy from the bath it took, Will use my KBS tank kit to wash and paint the inside. Will then get it in the car and think about the filler pipe.
On another matter has anyone fixed up there rear spring hangers them selves or is it just one things better to just buy them new..??   The Bolts are a bit worn on mine was thinking cutting the bolts out and replacing with some grade 8 bolts.
camxsmith
« Reply #262 on: August 18, 2019, 08:09:07 PM »
Cut and welded in the filler panel piece I had
Cleaned up the tank ready for KBS treatment
Also brought a Tacho to pull apart and incorporate into a FC Speedo
Has any one done a speedo conversion into KM and how did you get around the etch numbers in the bezel plastic Huh
Longman
« Reply #263 on: August 18, 2019, 08:31:56 PM »
Nice work mate, it's all coming together.
« Reply #264 on: August 19, 2019, 08:27:38 AM »
No stone unturned ,good on you ,looks great ..Vern
camxsmith
« Reply #265 on: August 28, 2019, 01:54:53 PM »
Got a little distracted from the fuel tank picked up a old drill press $31, brought her back to life with a rebuild.
Now back to car
Longman
« Reply #266 on: August 28, 2019, 04:31:26 PM »
Ah men, we are so easily distracted.
« Reply #267 on: August 28, 2019, 05:58:03 PM »
And obviously drive belt covers are for safety-obsessed wusses.
camxsmith
« Reply #268 on: August 28, 2019, 07:59:13 PM »
Its so funny how relaxed things were.  I do admit the picture does not have the original belt guard on the the front as I had not finished it at that photo taken time, but its just at the front and does not cover the full length of the belt ..  The below picture from the internet of the small cover I am talking about ..  Cheesy
camxsmith
« Reply #269 on: September 05, 2019, 03:43:13 PM »
Well Tank has been painted inside with KBS tank sealer and has had two coats on the top of KBS rust seal. Just the bottom to do and its complete
JOX515
« Reply #270 on: September 05, 2019, 04:28:30 PM »
Good progress Cam.  Mine is at a mate's workshop hopefully getting the subframe repairs done finally.... Once that is done only have to plug in number plate light, adjust handbrake, work out a way to secure the base of the back seat and redirect the front brake hoses away from the upper ball joint then good for RWC and rego.....
« Reply #271 on: September 06, 2019, 07:50:26 AM »
Isn't that KBS good stuff ? ,I have put some Black Hi Gloss on with brush ,really soft brush and warmed the paint up ,and " sopped " it on ..very happy with result..
camxsmith
« Reply #272 on: September 06, 2019, 08:59:49 PM »
That's so cool  Graeme  so happy you have an FC back in your possessio..  Also can not wait for you to take me for a spin
camxsmith
« Reply #273 on: September 06, 2019, 09:01:23 PM »
 Its amazing stuff the finish with just a brush is mind blowing..  One day we will be able to just paint our cars with a brush
camxsmith
« Reply #274 on: September 06, 2019, 09:11:00 PM »
Well The bottom of the tank is now coated in rust seal, next is a coat of the black top coat from KBS which should dry hard and protect the tank a bit more, as it hangs blow the car.
camxsmith
« Reply #275 on: September 08, 2019, 11:58:06 PM »
Added a piece to hold the filler pipe in place. Should be hidden behind the pipe  and connected to the wheel well
Also did some work on the tacho conversion. have the older one ready to meet the new
also made a plate to have the old inner parts meet the new. thinking I might just have some text in the mile slot. Ie. RPM x1000
camxsmith
« Reply #276 on: September 17, 2019, 12:05:42 PM »
Hi all  Did a little work on the Tacho.  Looking good so far
Welded up the new to old housings and converted the needle to fit the new tacho shaft (which was larger)
Quick test run, works fine
  Quick vid here
Next need to work out small sticker (RPM x1000), Numbers, bezel, and lighting make sure it all lights up fine.
Billy Blackarrow
« Reply #277 on: September 17, 2019, 12:20:45 PM »
You should be able to get the stickers you need from someone that makes signs, I got (brake fail ) done in reverse so I could stick it on the inside of the glass.
Billy Blackarrow
BILLY BLACKARROW
camxsmith
« Reply #278 on: September 17, 2019, 04:49:36 PM »
Billy Blackarrow
Good thinking Billy thanks, I will make some calls
Billy Blackarrow
« Reply #279 on: September 17, 2019, 05:33:42 PM »
Where are you i am in Newcastle N.S.W. are you close could give you the name  that did mine.
BILLY BLACKARROW
Pages: 1 ... 12 13 [14] 15 16 ... 19   Go Up
Page created in 0.063 seconds with 19 queries.
