August 28, 2025, 02:23:59 AM *
Pages: 1 ... 14 15 [16] 17 18 19   Go Down
Author Topic: Cams FC Resto  (Read 215174 times)
camxsmith
« Reply #300 on: June 27, 2020, 06:39:43 PM »
Im going with a heavy duty white line sway bar. And it looked close when I was doing a test fit and i did not want to risk it hitting later on. So while it was of and apart I added the scallop.
camxsmith
« Reply #301 on: July 03, 2020, 06:33:55 PM »
Some Floor work
New piece of tunnel between rear floors in
Started on the bottom A pillar on the passenger side, Made the replacement back plate
camxsmith
« Reply #302 on: July 05, 2020, 01:27:38 PM »
Man these a pillars are time consuming   Undecided
Started disassemble the problem area, inner section needs work as well
Started to shape
Cut away the old and in with the new
End of a full day and have one and half sides done with the inner dimpled circle made
camxsmith
« Reply #303 on: July 05, 2020, 05:06:49 PM »
The front section of the inner sill has a fancy u shape to hold the guard nuts, so a started on that. Found a couple bits of steel to fold it over at the right thickness.
Cut to shape
Test fit still needs a couple of cuts to get to fit
camxsmith
« Reply #304 on: August 09, 2020, 06:11:56 PM »
Nearly done on the A pillar
Also started on the chassis strengthening
First some 75x6mm flat bar bent to cut and bent to shape
Then added some crush tubes into the frame, for the grade 8 10mm bolt.
then the 75x35mm rail angle cut
then the front section setup ready to be cut.
camxsmith
« Reply #305 on: August 17, 2020, 04:49:09 PM »
A pillar nearly finished, just some cleaning up to do.
DJ
« Reply #306 on: August 17, 2020, 05:37:39 PM »
Really enjoying your step by step account Cam.
0417 270 315
camxsmith
« Reply #307 on: August 18, 2020, 08:33:38 PM »
Thanks DJ
camxsmith
« Reply #308 on: August 18, 2020, 08:35:40 PM »
Cleaned up and a quick coat of dry mark rust paint (that every ones is using..  Grin)
Finally got it done.
« Reply #309 on: August 18, 2020, 08:44:41 PM »
Great work cam 👍
2brite
Cruizin's devine in a '59
« Reply #310 on: August 18, 2020, 09:46:12 PM »
Looking good,keep the pics coming
camxsmith
« Reply #311 on: August 19, 2020, 05:52:50 PM »
Passenger side floor prep
then started to weld it in
camxsmith
« Reply #312 on: August 22, 2020, 05:29:03 PM »
Nice day to spend in the shed  Wink
Started with a hole (or hundred or so)
Made a tool for the small press
Then made a patch piece for the hole.
Then weld it in place
And start to position the new tunnel
Thats enough for one day
camxsmith
« Reply #313 on: September 06, 2020, 10:25:16 PM »
Some work from the fathers day weekend, focused on the tunnel arch. From all the replies on the ek auto floor I decided to go with a different design..
FireKraka
« Reply #314 on: September 07, 2020, 09:43:02 AM »
Hi Cam nice work mate what Shifter are you using I assume the brace wont get in the way of it.
Neil
camxsmith
« Reply #315 on: September 07, 2020, 03:20:04 PM »
Neil
Hi Neil  Im going to attempt a cable column shift.  So it should not matter to much..
FireKraka
« Reply #316 on: September 08, 2020, 09:45:45 AM »
Good work mate hope it works out for you.
Neil
Longman
« Reply #317 on: September 08, 2020, 05:12:32 PM »
Hey Cam, I'm doing the same, shifter mechanism from a tarago, cable from a falcon. Should work a treat.
camxsmith
« Reply #318 on: October 19, 2020, 08:44:01 AM »
Used cardboard to help with the werid shape of the bottom arch, cut it out and welded it in
Had to move the car for a quick project so I thought I would cleanup some parts laying around
inner headlight repair parts
Headlight globe holder
all sand blasted and rust treated, and polished
Lower HR suspension arms wire wheel sand blasted and rust treated
« Reply #319 on: October 20, 2020, 05:46:14 AM »
Good to see your still motivated Cam ..
Pages: 1 ... 14 15 [16] 17 18 19   Go Up
