July 10, 2025, 12:56:00 PM *
Pages: 1 ... 11 12 [13] 14 15 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 194987 times)
Longman
« Reply #240 on: July 08, 2019, 03:41:24 PM »
 Pretty sure they all use early commodore racks. I know both V6 conv and Rodtech require exchange racks, so no surprise that they can have TRW on them. I bought a Rodtech and grabbed a rack from a VH wreck as my exchange. I now have a V6 conversions one.
Hey mate looks like a V6 conversions one to me I have fitted 2 of theirs one to my FC and one to the ek ute I'm finishing they use a VH manual rack that is shortened and Im pretty sure both of my raks had TRW on them.
I have other photos of the fitup if you like Cam
regards
Neil
JOX515
« Reply #241 on: July 08, 2019, 05:25:16 PM »
Cam, my sedan is running a V6 conversions rack. Come over and check measurements, etc if you like. I will check the engineers report and see if that tells me what car it came out of...
camxsmith
« Reply #242 on: July 08, 2019, 06:41:10 PM »
Hi Graeme Are you around on Wednesday I will pop over check out the car.
JOX515
« Reply #243 on: July 08, 2019, 07:13:45 PM »
Home all day mate Smiley
camxsmith
« Reply #244 on: July 12, 2019, 12:28:52 AM »
Did some work on the left rear.
FireKraka
« Reply #245 on: July 12, 2019, 11:43:21 AM »
Hi Cam did you make the panel or purchase from somewhere?
Neil
waynos
patience grasshopper
« Reply #246 on: July 15, 2019, 08:08:55 PM »
looks good mate but why are you wasting your weld through primer.?
that stuffs expensive and paint doesnt like to stick to it
its not an etch primer.
dont get me wrong im not being a nitpicker.
just heard lots of bad reports about paint falling off that stuff
my8thholden
« Reply #247 on: July 16, 2019, 07:41:43 AM »
Wayno ..copper based weld thru primer which resists the heat that other etch primers don't resist so well, is used when after you weld you cant get back in there to protect the surfaces ,its not designed to paint over ,..cheers Vern ..
Longman
« Reply #248 on: July 16, 2019, 08:05:57 AM »
Good pics, am about to do the exact same repair on mine, using a Rare Spares panel.
« Reply #249 on: July 16, 2019, 09:44:28 AM »
I thought the idea of weld through primer was to capture some zinc in the weld pool. I suppose copper does the same job. Sorry bit off topic.
camxsmith
« Reply #250 on: July 17, 2019, 02:43:24 PM »
Neil
Hi Neil Purchased from rare spares on one of there sale days.
camxsmith
« Reply #251 on: July 17, 2019, 02:45:19 PM »
Your right Wayno I was being lazy and wasteful with the weld thur primer. It will be replaced with etch primer on the outside.
camxsmith
« Reply #252 on: July 17, 2019, 02:48:09 PM »
Errol I tried the zinc based weld thur primer, but I switched to cooper as I think the Mig welder worked better as it arked better and had less splatter.
camxsmith
« Reply #253 on: July 17, 2019, 03:08:35 PM »
Remove my rusty rear speaker surround and will add a couple of 6x9 holes for speakers
Also have sent the fuel tank into get its inlet moved. Thought I might play it safe and let someone else weld it up... Have done enough work on the car to see it to the end now Tongue
The tank work is being done by Regs Radiators, not sure if anyone else has used him. When I get the tank back I will give some feedback on his work.
my8thholden
« Reply #254 on: July 18, 2019, 07:58:29 AM »
Ditto to that process ,we use the copper where welding ,and where there is a bit of copper overspray ,then the etch primer will bond to the copper ,subsequently the paint ..
camxsmith
« Reply #255 on: July 22, 2019, 03:50:32 PM »
Bit of rust removal and clean up on the roof..  Couple of dents to be removed and when will work on the inside of the roof.
Still waiting for the fuel tank to come back to finish the boot space.
GMHwagoon
« Reply #256 on: July 22, 2019, 05:25:57 PM »
 What sort of insulation are you looking at for the inside roof ,
    fcwagoon
camxsmith
« Reply #257 on: July 22, 2019, 05:55:47 PM »
    fcwagoon
Good question seen the old Dynamat has roof lining... I’m sure there is a cheaper version...   have you used any.. ?
GMHwagoon
« Reply #258 on: July 22, 2019, 06:50:50 PM »
  Mine still has the black cardboard type in it, but some parts have dropped .so looks like l will be replacing the lot
   the worry is will these sound deadeners stick and stay there
   you can imagine the amount of heat that hits  the roof directly on top so hopefully someone
    has used something that works
       fcwagoon
camxsmith
« Reply #259 on: July 23, 2019, 07:53:44 PM »
Removed the ridge on the roof
Can see the long speed bump in the roof
Using a slap file and metal file knocked the bump down, then sanded to a nice metal finish
Came out better then I thought it would
Now to inside roof, one half cleaned up, removal of old sound deadner with low setting heat run and scrapper
then flapper disc and a coat of rust converter
Pages: 1 ... 11 12 [13] 14 15 ... 19   Go Up
Page created in 0.14 seconds with 16 queries.
