August 19, 2025, 12:01:57 PM *
Pages: 1 ... 10 11 [12] 13 14 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 212071 times)
camxsmith
« Reply #220 on: May 29, 2019, 05:52:40 PM »
Hi all has any one tried using a fuel link module, It transform's the ohm of any fuel sender to match your fuel gauge... I got one to match my tank to a smiths fuel gauge.  Hope it works. Wink
Also has any one seen or tried to convert a speedo to a tacho , or done any alterations to the dash panel ..  would love to see pics if you have ..  Im think of doing the following to my dash to have a speedo and tacho, wiper switch and light switch .. Fuel gauge move to guage pod ... i will move the ignition switch to right of the panel. Choke will be auto, high beam light to stay will make the tacho light be like ignition light (If that makes sense) and then add the indicator lights.. See what I can find.  Photoshop picture below
« Reply #221 on: May 29, 2019, 06:22:54 PM »
I used to have a Tacho mounted to the A pillar.
Ed Ho had similar dash to your design but extended through to the centre grille, couldn't find any photos though.
JOX515
« Reply #222 on: May 29, 2019, 06:33:22 PM »
That's a good looking dash you are designing there Cam Smiley
The dash in Glenn's pic looks pretty neat as well
« Reply #223 on: May 29, 2019, 06:52:39 PM »
A speedo is a nothing more than a tachometer, calibrated in miles per hour.
To convert one to a tacho, you'd need all the bits normally associated with a cable-drive tacho, and drive it from the engine instead of the gearbox mainshaft.  The most important part would be the distributor drive adapter.
I'm assuming you'd be custom-making a lot of these parts.  A Holden speedo turns clockwise when viewed from the rear, i.e. the same direction as the crankshaft, and the same direction as the distributor.  If you used a gear-drive, it would have to be set up to rotate in the same direction.
The next problem to consider would be what engine speed you wanted full-scale, and what angular sweep of the needle would correspond to that (270 degrees, for example).  Once you decided on those quantities, then the hairspring in the speedo would have to be changed or adjusted to give so many degrees of deflection at so many input rpm.
The more difficult part will be custom-making the glass and bezel to suit the tacho calibration.
And you could chuck the odometer out.
Or: go an electronic drive.  Sample the low-tension ignition pulses, scale the frequency to something suitable, feed the scaled frequency into a stepping motor driver, and adapt the stepping motor to drive the "tacho".  If you got the scaling factor right, you wouldn't need to modify the hairspring.  The glass and bezel would still have to be custom-made as in the cable-drive example.
All in all, I reckon it'd be an interesting instrumentation challenge.  Difficult, but nowhere near impossible.
camxsmith
« Reply #224 on: May 29, 2019, 08:04:42 PM »
Nice Glenn   That speedo fits well..  I like it thanks for the inspiration
camxsmith
« Reply #225 on: May 29, 2019, 08:05:44 PM »
Thanks Graeme  how the move going and the car..  your 28 day target must be closing in ...   did you need any help ?
camxsmith
« Reply #226 on: May 29, 2019, 08:13:19 PM »
Hi Rob   I was thinking of cheating and buying a electronic Tacho, mounting it onto the FC Speedo face and retro fitting the needle..  To change the location of the numbers was think of maybe some sort of clear perspex maybe molded to the shape and then vinyl sticks in the right locations. Do the same to the speedo to KM's ... Just as a rough Idea at the moment..  Make it look like it was made in the late 50's is the idea..  like it came on the car ...
JOX515
« Reply #227 on: May 29, 2019, 08:37:45 PM »
G'day Cam,
28 day target is not going to happen... House is now sold, new place is organised, settlement will be mid July, now to start packing the house up.
Waiting on a panel beater/painter to come and have a look at the car and hopefully that will happen this weekend. Got an electrics issue at the moment. Was looking for the reason for no indicators working and I think I have tripped the security system - got nothing at all when I turn the key. Hopefully the auto sparky will call over soon and perform his black magic.
What I did with my dash was graft new electronic gauges into the old instrument housings and a VL speedo assembly behind the FC dial and glass.
Will give you a yell if I need an extra pair of hands....
Cheers, Graeme
camxsmith
« Reply #228 on: May 29, 2019, 09:28:48 PM »
G'day Cam,
Cheers, Graeme
Yes I. An remember that dash in the wagon.. it’s in your posts as well   That was a nice dash
freddyc
« Reply #229 on: May 29, 2019, 09:43:38 PM »
graham, one of the keys has a proximity security system. It has to be near the car. There is a circle thing in the steering column I think that what that is.
fred.
PS I never tested it
Townsville North Queensland
camxsmith
« Reply #230 on: May 29, 2019, 10:24:04 PM »
Found some great pictures in the forum under . DONE MY DASH
I seem to find these post after I talk about them.   Tongue
« Reply #231 on: May 30, 2019, 04:54:36 PM »
Hi Cam, I adapted a GTR dash into the FC panel but lost room for the switches. This would have meant putting a panel under the dash for them. I wasn’t happy with the end look so I am now playing with an oval cluster from Dakota Digital which will allow me to relocate the switches diagonally on both lower ends and still maintain the size dash.
camxsmith
« Reply #232 on: June 10, 2019, 05:27:35 PM »
this weekend played with the gauge pod in the center dash....
First shortened an eh gauge pod and added the dash contour .
The made a frame for it to sit in.
Tacked the frame in to the center of the dash and trimmed the dash back to the frame..
It looks better then I thought it would  .. Will clean it up some more try making all gaps even
camxsmith
« Reply #233 on: June 10, 2019, 05:40:50 PM »
Also picked up one of the reproduction manual and cover..  going to be a nice item in the glove box.. amazed how close to the original it is..
camxsmith
« Reply #234 on: June 29, 2019, 04:23:41 PM »
Before I finish off the left rear quarter, I wanted to make my battery box holder. Much easier to make and tack weld when the out side is missing...  Included on the battery box holder is the isolation switch and a circuit breaker.
camxsmith
« Reply #235 on: July 07, 2019, 03:58:19 PM »
Hi All
       I picked up a rack and pinion off a HR front end. Just hoping some one could Identify which company kit it came from.  Im think its a commodore shortened. I could be wrong. And looks to be an after market TWR branded rack. But thats about all the info I have. lots of different numbers stamped into it.
the housing looks to be 355mm long
Longman
« Reply #236 on: July 08, 2019, 08:01:24 AM »
Hard to tell in those pics, but looks like a Rodtech kit. Workmanship looks too good to be a V6 conversions one.
Hi All
camxsmith
« Reply #237 on: July 08, 2019, 09:25:46 AM »
Thanks Longman
« Reply #238 on: July 08, 2019, 11:12:51 AM »
You could try ringing TRW and give them the numbers, they maybe able to track it down for you.
« Reply #239 on: July 08, 2019, 01:07:51 PM »
Hey mate looks like a V6 conversions one to me I have fitted 2 of theirs one to my FC and one to the ek ute I'm finishing they use a VH manual rack that is shortened and Im pretty sure both of my raks had TRW on them.
I have other photos of the fitup if you like Cam
regards
Neil
Pages: 1 ... 10 11 [12] 13 14 ... 19   Go Up
