August 19, 2025, 02:33:45 PM *
Pages: 1 ... 8 9 [10] 11 12 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 212186 times)
JOX515
« Reply #180 on: February 10, 2019, 09:35:20 PM »
G'day Cam  Smiley
camxsmith
« Reply #181 on: February 10, 2019, 09:43:26 PM »
G'day Cam  Smiley
I know, I know,  I hit the ENTER button a bit earlier..  Luck i could go back and edit the post...   Cheesy Cheesy  Thought I might get away with it.
JOX515
« Reply #182 on: February 10, 2019, 09:49:36 PM »
 Grin Grin Grin
« Reply #183 on: February 10, 2019, 11:29:20 PM »
Very neat job on the drain cam.
The butt clamps are great aren’t they.
camxsmith
« Reply #184 on: February 12, 2019, 05:13:01 PM »
Hey got a question for you all,  do roll up your rear fender lip..?  Mine was previously done just thinking i might clean it up and leave it like that..
Here is the promised pic from the missing section
Welded in just need to perform a little tidy up and it will be done.
« Reply #185 on: February 12, 2019, 07:52:07 PM »
It’s pretty essential if you run wide rubber specially if lowering cam. Years ago I managed to pull the non rolled lip out where the tyre contacted it on full lock. I was running 185 65 14 tyres on 6” rims set in as close to the top ball joint as I would dare on HR disc front.
FireKraka
« Reply #186 on: February 13, 2019, 10:48:48 AM »
Nice work Cam keep the photos coming mate I really like seeing builds on the forum it is a pity we are not seeing more.
I had an issue with my front tyres when I finished my Sedan and bought a guard roller off of ebay used a heat gun to gentle warm the paint so it didn't crack and again gentle rolled the guard out slightly, no more rubbing issue.  Grin
Neil
waynos
patience grasshopper
« Reply #187 on: February 16, 2019, 09:42:30 PM »
no real need for the lipped rear guard ..the inner guard pretty much sits out/in more than the lip
camxsmith
« Reply #188 on: February 17, 2019, 05:36:03 PM »
Your right there Wayno Will just clean it up then
waynos
« Reply #189 on: February 17, 2019, 09:16:36 PM »
depends what tyre youre gonna run.
im gonna try and get some more guard clearance seeing how close i can get that inner to the quarter panel.
seeing as though i got my 1/4 panel off i can check pretty easy
i will get back to you on that one.
anway youre doing great with the build .keep it up!!!!
« Reply #190 on: February 17, 2019, 10:03:49 PM »
I can’t help anticipating that you might want to tidy up and improve that inner wheel well area while you have such good access to it Wayno. It is pretty common to bend the seam up and move the tub wall in for an additional 20mm or so clearance as you are more than likely aware.
« Reply #191 on: February 17, 2019, 10:11:25 PM »
Apologies for hijack Cam. What I was going to say about the wheel arches, I agree you don’t gain any clearance as the inner guard is in the same plane so to speak. On the other hand you see it on a lot of cars, mainly the type that crawl over speed humps etc. they run wheels that just sit under the outer edge and look great. Hard cornering and unexpected bumps cause the tyres to rub occasionally.
camxsmith
« Reply #192 on: February 22, 2019, 03:23:15 PM »
Thanks for all the feed back guys.  After some in vestigating I was reward with some of my old friend. mr rust.  Grin. So I have to make a decision on the cut out and how much.
camxsmith
« Reply #193 on: February 22, 2019, 07:37:20 PM »
Few little finds at the Ballarat sap meet.
Glove box badges. External door handles. Wiper motor VN. Wiper bezels. Fuel cap. Internal door pulls.
Now I have a question about glove box badges.. There are different types can some one put together some images With what models they were on..  Just some home work for you all.  Now I say that I hope the info is not already in the forum.  Roll Eyes
Stewy
sa-club
Jeff Stewart
« Reply #194 on: February 22, 2019, 10:31:21 PM »
There are only 4 in FE/FC glovebox.
Holden Special on the FE specials
Special on the FC specials
Station Sedan on FE/FC station sedans
and a plain solid bar with 3 markings, the centre and each end. on the standards, commercials and business sedans.
Cheers Stewy   Cool
camxsmith
« Reply #195 on: February 23, 2019, 09:01:32 AM »
Cheers Stewy   Cool
Thanks Stewy Thats just what I was looking for.
camxsmith
« Reply #196 on: March 25, 2019, 06:08:50 PM »
Hi all
Just some seat belt plate work this week.
Cut out plates to spec's 150x75 ,   100x75 and 75x50,     > 5mm radius corners
Got my 7/16 UNF nuts grade 8 and weld them on, (I have also converted to copper based weld thur paint compared to the zinc which spatters alot more)
Used a length of wire to pull the B pillar plate up to its position. Helps that the bottom of the B pillar is off..   Grin  Then used a long bolt to pull it into position before spot welding into position.
Also welded up the outer hole on the B Pillar.
« Reply #197 on: March 25, 2019, 06:57:16 PM »
Nice work Cam. Have to do the b pillar on my ute but it is a lot easier as it is wider, there are access holes, and the inside is covered by the head lining, so the plate can be screwed or pop riveted in place.
So which plate goes where? I’m guessing the larger plate on the buckle side and the narrow one must go in the top of the pillar. By the way it looks like the long plates at the top might be 150x35, not 75.
Clay
camxsmith
« Reply #198 on: March 25, 2019, 07:31:48 PM »
You got me Clay
       They are 150 x 35 and they go at the top of the B pillar.  75 x 50 at the bottom and the 100 x 75 are for the double point in each side of the tunnel.
waynos
« Reply #199 on: March 25, 2019, 08:01:33 PM »
so the b pillar plate has enough surface area..ive been going to make mine pretty soon and was wondering what size to do.
thanks for saving my time on google and this forum looking it up!
always hated that bolt head sticking outside the car
made sure i chopped my roof either side of that hole so i didnt have to fill it  Wink Cool
Pages: 1 ... 8 9 [10] 11 12 ... 19   Go Up
Page created in 0.049 seconds with 16 queries.
