camxsmith
« Reply #160 on: March 25, 2018, 06:14:48 PM » |
cam if your interested l have that inner square panel can send a pic lm in bacchus marsh
fcwagoon
That would be awesome Greg send me a pic and how much you I want for it, Thanks mate
GMHwagoon
« Reply #161 on: March 26, 2018, 02:39:30 PM » |
GMHwagoon
« Reply #162 on: March 26, 2018, 02:40:31 PM » |
camxsmith
« Reply #163 on: July 21, 2018, 08:08:19 AM » |
Hi all Well I have been a bit slack when it comes to the car, but I did pick up a couple of bits and pieces and make some butt weld clamps. 186S headers     Chrome Indicator stalk (HR HD) which I believe matches the HT chrome gear lever better.  Weld Clamps  Do have some question for you all. Any one had there exhaust or parts ceramic coated .. ? want to know is it worth it and who they used. Also with the outlets of the orginal headers do both holes have threads  .. the ones I picked up only have one hole threaded, I think this might be as the other holes failed and then been drilled out.
« Reply #164 on: July 21, 2018, 08:49:47 AM » |
Nice score on the headers Cam. I believe both holes should be tapped. I painted mine with Duplicolour high heat rattle can. Contains ceramic apparently. It is looking ok but I’ve only warmed it up a few times since fitting the manifold, which is stock 186. A budget solution as the motor may be replaced by a grey. Cheers Clay
my8thholden
Offline
« Reply #165 on: July 23, 2018, 07:19:28 AM » |
All the best with your resto Cam ..Mine, a FC Sedan special is about the same stage body wise ..Have built a new grey motor ...I cant post images ..I have an iPhone 3 ..tried direct from phone..have created a file ..just wont up load ..can you send step by step ..no young ones here very often to give me a guide..some of the guys here in Sydney asked me to post images as we progress the resto ..if you read this Ken ..I sorted the "miss " in the engine ..I cant say exactly what it was ,other than a combination of distributor and carby problems ...Vern
59wagon
« Reply #166 on: July 23, 2018, 03:55:26 PM » |
Nice job with the clamps, Cam. Got a bit of panel welding coming up? I've spoken to a few people who've had their headers ceramic coated and they're all pleased with them. Apart from looking good, they reduce heat to surrounding parts. These jobs were all done in WA, though - probably a bit far for you  From what I've read in the past (but have no experience with or know anyone who's had them long enough), they should also look and last longer due to less heat cycling. As far as "Are they worth it?" - I can't answer that as it depends on your own needs/wants/budget I think. Cheers, John
camxsmith
« Reply #167 on: July 23, 2018, 09:20:48 PM » |
Thanks Clay and John for the feed back.. I would expect that the old rattle can jobs like the dupi and VHT FLAMEPROOF™ COATING would work ok. And would look great for a long time, but I would think the thicker coating that the company's put on would be much better with the heat side of things. I might try the VHT FLAMEPROOF™ COATING, have seen a few reviews of it been good and looking great after years of use. At roughly $20 a can I would only need one or two cans. I'm sure the local companies the do ceramic coating would be close to the $200. If the rattle can bubbles and peels some years down the track I'm sure I can remove it and get it done professionally. And yes plenty of panel work for Cam coming up...
camxsmith
« Reply #168 on: July 29, 2018, 11:07:17 AM » |
Some updates Rear section behind the fuel tank . added water weep holes using home made dimple die.  Cleaned up exhaust manifold  First coat of VHT flame proof primer.. VHT Flameproof coating
59wagon
« Reply #169 on: July 29, 2018, 01:06:27 PM » |
Good stuff Cam. Can you show us your home made dimple die? Cheers, John
camxsmith
« Reply #170 on: July 29, 2018, 06:02:19 PM » |
One home made dimple die  A few trial runs to make it right... for the size I wanted. I used my 20ton hydraulic press to push the die together..
59wagon
« Reply #171 on: July 29, 2018, 10:50:17 PM » |
I love a home made tool 👍👍👍
VAN059
Offline
Brisbane, QLD.
« Reply #172 on: July 30, 2018, 07:21:28 AM » |
Nice work Cam!
my8thholden
Offline
« Reply #173 on: November 04, 2018, 07:48:09 AM » |
Hi Cam ..Yes you have a project ahead of you ,just like me ,I note your engine bay looks to be originally body colour like mine over done later in black ,same as mine ,it must have been 'the thing to do ' ..any way i'm back to original India Ivory in the bay ..It looks good..bugger of a job ,lots little hard to get to places ,but im happy with final result.. By the way ,thanks for your advice on posting images ,and to Dave Bolton ..My daughter finally had time to sit down with me ,she is not familiar with Imgur .and I know nothing.So I now have a FC Holden file on this PC where I put images from my phone .She has made it simple ,on the forum site when I select "add image to post " up comes the FC Holden file in " POST IMAGE" ,I select what I want ,and bingo ..They are smaller than other images ,but viewers can double click on them and enlarge ..I'll watch your resto also with interest .. I found a guy in my area who is on the RMS web site as engineer and authorised inspector for safety equipment ,,I contacted him with regards fitting seat belts as my car has never had any ,and some guys on this forum have supplied me with some info ..Interestingly..he said " I got my certification because I wanted to specialise in child safety seats and harnesses ,when I advised my business insurance company ,they put the premiums thru the roof ,so I gave it up "...Govnm't encourages small business ,corporations kill it "
camxsmith
« Reply #174 on: February 02, 2019, 09:52:35 PM » |
DJ
« Reply #175 on: February 02, 2019, 10:35:18 PM » |
The heather switch concept is interesting Cam. Looking forward to seeing what you come up with. Some real good metal shaping & patching going on there too.
Dave 0417 270 315
my8thholden
Offline
« Reply #176 on: February 03, 2019, 07:01:55 AM » |
Hey Cam ..your really into it ,Tramp rods ,I think were K'Mac ,and they had front anti sway bars also ,and Armstrong offered heavier shocks to go with them. Dismantalling is easy ,putting it all back I reckon is 4 to 6 times at least slower ,that's the final satisfaction that makes it worth it ..Don't good pics make a difference to post ...Vern
« Reply #177 on: February 03, 2019, 09:16:54 AM » |
Good progress Cam. Yep photos are gold, thanks to the lass.
59wagon
« Reply #178 on: February 04, 2019, 02:41:13 AM » |
Nice patchwork Cam. I used a similar globe for my FB interior and like the result - it gives a much whiter light.
Chees,
camxsmith
« Reply #179 on: February 10, 2019, 09:27:42 PM » |
« Last Edit: February 10, 2019, 09:40:48 PM by camxsmith »
