July 06, 2025, 07:28:41 PM *
Pages: 1 ... 9 10 [11] 12 13 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 194891 times)
59wagon
« Reply #200 on: March 25, 2019, 10:50:41 PM »
so the b pillar plate has enough surface area..ive been going to make mine pretty soon and was wondering what size to do.
thanks for saving my time on google and this forum looking it up!
Hi Waynos, it might be worth checking VSB14 which gives you the minimum size (area) and metal thickness (thicker is not better), plus a few other bits to consider. Here's a link - scroll down to about page 13.
https://infrastructure.gov.au/vehicles/vehicle_regulation/bulletin/files/NCOP7_Section_LK_Seating_and_Occupant_Protection_1Jan2011_v2.pdf
« Reply #201 on: March 25, 2019, 10:53:07 PM »
Just a bit of advice guys, if you are putting side and middle belts in i.e. RH, LH and centre the ADR’s now require a separate anchor point for all belts. I had to redo mine as I only had one either side of the tunnel for the side buckles and the centre lap belt.
camxsmith
« Reply #202 on: March 26, 2019, 04:50:55 PM »
thanks for that guys , and i apologies for my 150 x35 size that I quoted. Its not even the size I cut in the shed mine are 150 x 30 which might need some adjusting.
The ADR states
   The device must be shaped to match the contour of the mounting surface and must have an area of not less than 3750 mm² in contact with the mounting surface.
150 x 30 = 4500mm²   which seems to much, I should of been closer to 25 width or 125mm in length.
My 75 x 50 plates   are right on the minimum value of 3750, and i will now cut up my 100 x 75 making the extra middle plates.
Lucky I have not gone to far with this.. Tongue
waynos
patience grasshopper
« Reply #203 on: March 26, 2019, 06:49:56 PM »
you cant really go oversize only on thickness
its a minimum square area isnt it?
« Reply #204 on: March 26, 2019, 07:29:03 PM »
I wouldn’t be overly concerned about the oversized plates, it’s better to be to large than to small. From memory I made my plates 100x75x3mm for the parcel shelf and inner guards, 200x75x3mm for the b pillars and I changed the floor plate to 1000x100x3mm and bent it to fit under the tunnel.
I’ve replied to your message with the page number on my build page with pictures.
camxsmith
« Reply #205 on: March 27, 2019, 10:11:03 AM »
Thanks Jim
camxsmith
« Reply #206 on: April 17, 2019, 10:22:55 AM »
Doing the passenger side rear lower quarter
waynos
« Reply #207 on: April 17, 2019, 06:19:47 PM »
do you have english wheel?
camxsmith
« Reply #208 on: April 18, 2019, 10:04:45 AM »
No english wheel but that would speed up things..  would be great to have..
waynos
« Reply #209 on: April 19, 2019, 10:32:41 AM »
how are you gonna put in the compound curve?
camxsmith
« Reply #210 on: May 12, 2019, 09:22:17 PM »
Sorry Wayno for slower response...   I'm guessing your talking about the lower lower rear quart panel,  my answer is just buy one and welder it in.  Grin
camxsmith
« Reply #211 on: May 12, 2019, 09:30:07 PM »
Hi
    Got a wiper switch the same as the well known Brett's wiper conversion post, pay $50 deliverer which as a little score (On days prices). Over the weekend had a bit of a play on the lathe making a new knob. Use a cold chisel to put some gripping groves for the chrome insert. Needs coat of black and maybe different screw but happy with the result.
« Reply #212 on: May 13, 2019, 08:17:58 AM »
Very cool.
« Reply #213 on: May 13, 2019, 09:16:55 AM »
 Wink
59wagon
« Reply #214 on: May 13, 2019, 03:29:26 PM »
Good job Cam  Smiley
« Reply #215 on: May 13, 2019, 07:48:58 PM »
Looks good
waynos
« Reply #216 on: May 14, 2019, 06:10:29 PM »
ok got ya.where you getting panels from?i just bought a tailgate skin off retro spares..its really good.i was pleasantly surprised
« Reply #217 on: May 14, 2019, 06:58:37 PM »
Mate got tailgate skins $150 from Qld mob on eBay, not Taylor’s. reckons they’re good. He was up that way so didn’t have to pay freight, and he reckoned was a good price. Either way they are both half the rare spares price if you can deal with the freight.
camxsmith
« Reply #218 on: May 16, 2019, 09:02:47 PM »
I have a section of Taylor’s and Rare's  Neither have been perfect but all have been a million dollars better then the crap I cut out..   Wink
waynos
« Reply #219 on: May 17, 2019, 04:15:15 PM »
i reckon retro spares is getting them from the same guy in queensland,i bought it from victoria but it came from queensland looking at the postage
anyways its a decent bit of stuff.im about to buy an english wheel .i was going to make one and was thinking i would just buy one to see how good it was.if it was crap id just sell it on.its so good im using it,sav ing me 1000 dollars right now for the wheel and shrinker stretcher i would have needed to make it
Pages: 1 ... 9 10 [11] 12 13 ... 19   Go Up
Page created in 0.069 seconds with 18 queries.
