September 08, 2025, 11:51:43 AM *
Pages: [1] 2 3 4   Go Down
Author Topic: 1958 wagon  (Read 56689 times)
customholden
« on: December 03, 2010, 08:30:41 PM »
« Reply #1 on: December 03, 2010, 08:33:09 PM »
That will keep you busy!
Good luck with your new project.
GOA350
« Reply #2 on: December 03, 2010, 09:23:53 PM »
So, don't hold back.    What's the story that goes with this one.
customholden
« Reply #3 on: December 03, 2010, 10:10:33 PM »
was going to put a 350 chev in her but i have found out it would not be legal in Qld so i am going to use my Rb30 instead and look at putting a rb25 head on the rb30 block and turbo it. I will be doing all the work myself except for the retriming of the seats and door trims. I am going to start stripping it down in the morning.
« Reply #4 on: December 03, 2010, 11:25:54 PM »
Good luck with it, keep us posted on your progress.
F4+ Wink
customholden
« Reply #5 on: December 04, 2010, 07:04:54 AM »
started ripping the gaurds, bonnet, grill etc off this morning. having fun with the rusty old bolts and round nut Angry lucky i am replacing every nut and bolt i have broken half already, Smiley
customholden
« Reply #6 on: December 04, 2010, 02:30:40 PM »
engine and gearbox out and subframe needs a rebuild too.
and i should proberly fix the leak in the fuel tank Cheesy
now you guys know why i wanted to put a full chassis under it and replace everthing but the outer shell with new steel
fb delivery
« Reply #7 on: December 04, 2010, 04:00:47 PM »
I looked at buying this car at warwick
good luck with it
  Cheers Rob
customholden
« Reply #8 on: December 04, 2010, 04:37:45 PM »
 first test fit of the engine
« Reply #9 on: December 04, 2010, 04:44:46 PM »
Good to see that you are getting your teeth into it. I can see why you want to go the route of fabricating a new chassis, there is certainly a fair bit of tin worm in there. Keep us posted on your progress Smiley
Good luck with it
F4+ Wink
customholden
« Reply #10 on: December 11, 2010, 03:33:58 PM »
i have pulled all the interior out and cleaned up whats left, wich is very little metal and all rust. by the time i cut out all the rust the will be No floor, No sills, half a front subframe, even half the rear left door will be missing. I have desided it is too far gone to just fix the rust and modify but i will have to re fabicate and reengineer the car as a hot rod. i will buy new outter skins for the sills and doors that need replacing. and i will be fabricating my own inner sills and chassis kit to fit a new sheet metal floor (keeping the original bench seat mounts to refit the benchy. I will be shortening a commodore diff from a vn to vs which i am still looking for a full doner car to buy. Will use the same brakes and hubs on the front from the doner car and make my own hot rod style front and rear end. running airbags all round and lowering the body 50mm over the standard suspension height so once bags are lowered the sill will be as low to the ground as possible (if not on the deck). i have realist that while i will be going as refabing the chassis and suspension i might as well go the whole hog and do the V8 instead of the Rb30. i will deside later if i use the 350 chev or twin turbo my 253. but it will now be V8 not a street 6. i will find a less rust old holden for the street 6 rb30 motor and make it a daily driver. missus wants an EH
« Reply #11 on: December 11, 2010, 08:11:59 PM »
sounds like yer gunna be very busy. may as well make a full chassis as u want to and go full fibreglass panels  Grin make it a light v8 runner for the strip! I wouldn't bother twin turbo'ing a 253 though, i may as well turbo the rb30 and it would shit all over the 253 for durability  Wink
customholden
« Reply #12 on: February 06, 2011, 08:13:39 AM »
i pick up a vn commodore wagon for parts. it was a vr v6 engine in it and auto. drive allreight on the way home too.How many parts could i use? diff, fuel tank and brakes are main reason for getting but what else can go into my fc wagon?
« Reply #13 on: February 06, 2011, 08:37:06 AM »
Floor , fuel tank, handbrake , wiring etc. This is a link to Pedo's build and can give you some idea's of what is possible. Hopefuuly the page will take you to the floor replacement.
http://fefcholden.org.au/forum/index.php/topic,13258.180.html
It is 30 odd pages but well worth a read.
Rgds
Wayne
« Reply #14 on: February 06, 2011, 01:23:28 PM »
Have a look at sgo build, I recall he used just about the whole doner car!
this link to his project may or may not work
http://fefcholden.org.au/forum/index.php/topic,607.0.html
sgo
« Reply #15 on: February 06, 2011, 09:19:01 PM »
Dash inc switches,wiring & fuses & computer,front seats,rear seat,steering wheel & column & rack,all pedals,brake booster and m/c,wiper motor,engine & gearbox & gear shift,radiator,front discs,petrol tank,cat,wheels,fuel lines, carbon cannister,handbrake,interior light,centre brake light,rear seatbelts,V6 badges.
And I'm sure there's other bits I've forgotten Roll Eyes
customholden
« Reply #16 on: February 14, 2011, 07:00:36 AM »
i had a play around with the two wagons on the weekend and has desided to use the whole commodore car and fit my FC to the commodore. the only mod plate i will need is for the front bench seat when i remove the buckets.
customholden
« Reply #17 on: February 14, 2011, 06:05:49 PM »
 you get the idea. i am going to put the front and rear on the commodore and see about the side door skins.
MattFC
Adelaide
« Reply #18 on: February 14, 2011, 06:38:25 PM »
I reckon it looks good as it is, bit of bog to fix the panel gaps and she'll be sweet! Cheesy
« Reply #19 on: February 15, 2011, 08:14:20 AM »
this will be interesting!
I reckon blend the rear of the commo guards into the FC guards and get the wheel sitting centred in the FC guard to start.
keep us updated
Pages: [1] 2 3 4   Go Up
Page created in 0.053 seconds with 18 queries.
