July 19, 2025, 12:01:02 AM *
Pages: [1] 2 3 4   Go Down
Author Topic: Smiths clock bracket  (Read 32448 times)
ridgey_didge
act-club
« on: October 16, 2013, 05:00:36 PM »
Can anyone help me with specifications for a bracket for a Smiths Clock (that goes on the rear view mirror stalk).  If someone has a bracket for sale that would be ideal.  Ken McL did post a few years back that he had a drawing for the bracket, but I have checked with him and alas, he has it no more.
If someone has a clock with bracket, could you do the measurements for me and maybe send me some close up photos?  My email address appears on my profile.
David
FCV08
FE FC Club of QLD
« Reply #1 on: October 16, 2013, 10:04:41 PM »
David
If you get some drawings or photos can you email them to me as well?
Craig D
« Reply #2 on: November 19, 2013, 08:12:08 PM »
With thanks to Zulu, I have retrieved my original drawing which is reproduced here with mock up sketch.
if you want a copy sent to you then give me a pm
« Reply #3 on: November 19, 2013, 09:01:37 PM »
I can cut them on the waterjet
supply as a flat pack probably only take 30sec to cut ?
« Reply #4 on: November 19, 2013, 09:29:54 PM »
I'll send you the drawing, send me a pm with your address. The drawing is on paper, not electronic.
« Reply #5 on: November 19, 2013, 09:35:49 PM »
Should be enough detail there ill draw it tommorow on cad see how I go.
What material and thickness ?
pete
« Reply #6 on: November 19, 2013, 09:47:11 PM »
1mm mild steel
« Reply #7 on: November 19, 2013, 09:57:10 PM »
Distance between holes C is the distance between the holes on the mirror (I didn't have one here to check). The distance B to the side wall is half that distance minus 2 mm
« Reply #8 on: November 20, 2013, 04:55:07 PM »
I need the distance between hole centres on an FC mirror bracket from someone who has one handy please.
Thanks Ken
« Reply #9 on: November 20, 2013, 11:08:42 PM »
Ken, 1-3/8" or 35mmtaken from the mirror base and the holes in the support.
Regards Jim
FCV08
FE FC Club of QLD
« Reply #10 on: November 20, 2013, 11:10:33 PM »
Beat me by 30 seconds.
I got 36mm but leave it at 35mm due to parallax error
Craig
Stewy
sa-club
Jeff Stewart
« Reply #11 on: November 21, 2013, 09:11:55 PM »
Picture of what it looks like.
Cheers Stewy   Cool
« Reply #12 on: November 22, 2013, 08:32:41 AM »
I cannot see the drawing properly to replicate it so if someone faxes it to me i will get a few cut should be around $6 each in 1mm zinc.
ridgey_didge
act-club
« Reply #13 on: November 22, 2013, 09:09:24 AM »
Pete - send me your fax number by PM and I will send you the diagram once my hard copy arrives from Ken.  I am happy to be your first customer at the (no room for bargaining) price of $6.
David
« Reply #14 on: November 22, 2013, 10:18:02 AM »
0265746311 its a open fax number for the business.
FCV08
FE FC Club of QLD
« Reply #15 on: November 22, 2013, 11:38:41 AM »
I'll be in for one as well Pete
« Reply #16 on: November 22, 2013, 12:20:41 PM »
Had a go at tweaking the shot Ken posted but no better for reading a couple of the dimensions, sorry. A fax may not transmit any better even on a fine setting. Enlarging may work though & sending several pages to put together.
It's a good diagram, maybe just a couple of closer shots of the measurements would do the trick.
« Reply #17 on: November 22, 2013, 01:06:10 PM »
I think kens onto it anyway.
« Reply #18 on: November 22, 2013, 06:44:09 PM »
original has been posted
ken
« Reply #19 on: November 22, 2013, 07:10:04 PM »
thanks ken.
Pages: [1] 2 3 4   Go Up
Page created in 0.048 seconds with 16 queries.
