July 18, 2025, 10:06:36 AM *
Pages: 1 ... 3 4 [5] 6 7 ... 12   Go Down
Author Topic: FC Another Tassie car  (Read 184559 times)
ekute
« Reply #80 on: July 14, 2013, 07:40:19 PM »
Nick,
Have done the same repairs but not as extensive, great job, keep it up!
NickZ
« Reply #81 on: July 20, 2013, 05:59:29 PM »
not much done today.
ill have a month of grinding.
Maco
« Reply #82 on: July 20, 2013, 08:59:18 PM »
Nick,
Nice work, I have the Rubbers that fit between the body & the bumper available, if you require them.
Better in Green
« Reply #83 on: July 20, 2013, 09:43:52 PM »
Well done NIck. Were u born in Tassie.
NickZ
« Reply #84 on: September 01, 2013, 06:19:18 PM »
Yes i was born in tassie.
I finished all the underneath but forgot to take a picture of it painted in sound deadener but im sure we have all seen one before.
got the rear springs, diff and brakes all done.
measured my track with some mag wheels i had lying around and the track it 1390mm, 6mm over, but ill try some other wheels later. Will 6mm even matter?
« Reply #85 on: September 02, 2013, 08:09:06 AM »
Great work mate. How much clearance is there between the bracket on the backing plate where the flexible line meets the steel line and the subframe and  the inner guard up near the bump stop. I'm just wondering because I've had to relocate that bracket onto the housing on a few conversions where the rear end has been over shortened. Anyway keep up the good work .
« Reply #86 on: September 02, 2013, 09:40:17 AM »
I have also had to move the flexible  brake line bracket to a lower position on all of the conversions I have done .with the Commodore rear end .....FC427.......
« Reply #87 on: September 02, 2013, 09:52:04 AM »
@hsv-001 You seem to have done that a few times now (asked that is). Don't recall FCRB26 having a problem and I sure didn't
« Reply #88 on: September 02, 2013, 11:46:08 AM »
My Ute doesnt hit.
My sedan which is heavilly moded needed the rear calliper mount rotated down 20 degrees
« Reply #89 on: September 02, 2013, 03:31:01 PM »
Mate could you explain it to NES304 as I'm not enjoying it anymore. Wayne's rear axle was too short[Old Mt Isa boy] From memory I think he told me he got the measurement off this forum [maybe it was the measurement for a drum brake rear end]. When I installed it there was no handbrake brackets on it. Whoever shortened it removed them, also  being that short the distance between the brake line mounting brackets was less than between the inner wheel arches [tubs] and I have seen so many of these axle conversions over the past 20 years and its not a problem till you are carrying a load and don't see the speed bump. So I'm sorry its getting repetitive but if you are not experienced at these mods find someone with a car or cars that have these mods and have been driven[for decades if possible] then copy theirs. Incidental this is probably why the crewman mounts the handbrake cable on the leaf spring[to allow for a maximum size wheel by keeping the axle short] they might have used a different offset or provided for a larger than  standard rim. Anyway I'll leave it alone from now on.
NickZ
« Reply #90 on: September 02, 2013, 08:20:16 PM »
I shortened my diff 50mm each side, i went for standard track with standard commodore 15'' wheels 1384mm (currently at 1390 with mag wheels).
I have 15mm clearance for both flexible hose and bracket , its something i didn't think of untill now, but there is no issue, it clears.
« Reply #91 on: September 02, 2013, 09:43:01 PM »
HSV001 - Hey mate I wasn't having a go just wondered why you asked on two different threads?
Did mine 67mm both sides
As far as I am aware my crewman has the same offset as a sedan
NickZ
« Reply #92 on: September 02, 2013, 10:55:53 PM »
well that would be the reason yours is fouling, my 50mm + the 15mm gap = 65mm so your 67mm would hit. So what is your total track measured to the centre of both tires, it should be 1384mm
You must have wanted to run some large offset wheels?
fink
« Reply #93 on: September 02, 2013, 11:37:23 PM »
If you get desperate,iv'e got a few HP mtrs here,i can drop one off at the SAT,it's just down the road from me,Gaz! Cool
« Reply #94 on: September 03, 2013, 12:37:52 AM »
Hey Nick what I have been trying to say is ... It's NOT fowling. Yeah I have different offset rims so track width is completely different and would be for other sets of rims not standard commodore
« Last Edit: September 03, 2013, 12:50:04 AM by NES304 » Logged
NickZ
« Reply #95 on: October 10, 2013, 06:33:59 PM »
Got some primer on the front end and firewall today, i hope to get colour on by saturday.
then i can start to put all the mechanicals in.
« Reply #96 on: October 10, 2013, 07:32:31 PM »
Great progress but still concerned about your rear axle. If those are the original bump stops and they are in the original positions then they will serve no purpose as the fc fe axle has brackets in front of the housing that they bottom on. If you cant get a set that mount under the 'u' bolts [hr or torana] have a look at what Wayne [old mt Isa boy ] did with hq bump stops. Keep up the good work , I'm watching with interest. Cheers.
NickZ
« Reply #97 on: October 10, 2013, 07:40:20 PM »
i didn't know about the bump stops, ill look into it.
NickZ
« Reply #98 on: October 11, 2013, 05:59:03 PM »
I got some colour on today, Im very happy how it went on. Now just have to block back a couple of runs and put a few coats of clear.
NickZ
« Reply #99 on: October 12, 2013, 07:19:58 PM »
finished painting for now.
ill put the engine in this week.
Pages: 1 ... 3 4 [5] 6 7 ... 12   Go Up
Page created in 0.043 seconds with 16 queries.
