July 14, 2025, 02:58:46 PM *
Author Topic: Fan Shrouds  (Read 4514 times)
« on: October 10, 2018, 01:17:59 PM »
My 202 powered FE Sedan runs normal temperature in most driving situations, but when stuck in slow traffic or forced to sit idling for a while the temp creeps up past 180. I have tried a thermo fan in front of the radiator to push air through but this did little.
Have people fitted fan shrouds to their Red 6 powered cars?
Does it improve cooling?
How did you do it/what did you use?
« Reply #1 on: October 10, 2018, 04:10:54 PM »
I haven’t tried a shroud but had similar problems with over bored motors also too small a fan. Three core HT radiator fixed the over bored motor. What radiator are you running stinky? Has the motor been bored out? Running a stock EH HQ fan I assume?
« Reply #2 on: October 10, 2018, 04:55:40 PM »
The 202 is standard bore, the radiator is from an LC/LJ Torana but the core was upgraded from standard, twin row fine core?.
FE_UTE
« Reply #3 on: October 10, 2018, 07:30:07 PM »
I have a 186/235 with a flex fan on the motor...a high flow thermostat..a quality thermo fan that I switch on in traffic and a larger three core radiator
Hottest days 38+ idling in traffic 190 with thermo on ,  would get to 200 without the thermo on ...towing the teardrop 180 - 185 all day
« Reply #4 on: October 11, 2018, 11:52:00 AM »
Ok , I would have a 1981 Nissan Bluebird fan shroud in the shed , thing is I know that the shroud will fit perfect on a Torana [LC LJ], just saying . But I have said it before that when you put a V6 into a 1948 Vauxhall you would be best to change the thermostat to a cooler one [V6 commodore run standard at 110 degrees C] and here is the crucial thing ,I run a dial up thermostat in the top radiator hose and set it to switch the fan on earlier than the temp switch would normally , its totally adjustable so you could reset for towing or heavy traffic  It was a thing that you didn't need a engine driven fan on your car if you were at speeds over 30mph as the airflow was adequate ,so maybe your electric fan isn't good enough to push air through your radiator . When I build a vehicle I will test the cooling system in the shed to make sure the fan will cool the system [turn off and on ] . Sometimes in the past I have even considered and have put the splash guards back on to direct airflow back toward the firewall . Cheers mate ,any questions just call on 0755477094 .
Page created in 0.038 seconds with 20 queries.
