April 04, 2025, 10:58:05 PM *
Pages: 1 ... 13 14 [15] 16 17 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 191375 times)
« Reply #280 on: September 17, 2019, 05:44:09 PM »
Cam  .Can give you a guy in Sydney also who did my gauge letters .for inside glass application , OIL , GEN ,TEMP ,FUEL  E  F ..all on line ..Vern .
camxsmith
« Reply #281 on: September 18, 2019, 08:33:12 AM »
Thanks Guys Im in Victoria tho ..  I might try the locals first, least then i get the chance to go in and check the work out.  If it falls thur I will get the NSW guys off you
camxsmith
« Reply #282 on: October 31, 2019, 11:33:35 AM »
Well no better to time to start on the dash
cut lines
One side stitched up
Other side now
camxsmith
« Reply #283 on: November 09, 2019, 09:57:39 PM »
Well bit of a test fit and things are going well
Just need the add the signal light recess  and give it a good clean up and paint, Then its on to the ignition switch position on the dash and clean up the four gauge mount
camxsmith
« Reply #284 on: November 14, 2019, 02:42:51 PM »
Well got the indicator light recess in and now just need to test fit all switches and a coat of filler and paint
Picked up a clean grill, will use a few of my own good chrome bits to finish it off, But very happy with it.
59wagon
« Reply #285 on: November 14, 2019, 04:36:54 PM »
Nice work on the instrument cluster Cam 👍. Can you show us how you put the indicator recesses in ?
Cheers, John
camxsmith
« Reply #286 on: November 14, 2019, 08:48:10 PM »
Cheers, John
John I wish i could say I used some home made jig and pressed them out ..  but all I did was used the old recess from the cluster I cut up ..  then just filled in the slots with some weld. Drilled the holes out to the correct size. simple as that.
« Reply #287 on: November 14, 2019, 08:53:51 PM »
It looks great Cam. Worth the extra mile.
camxsmith
« Reply #288 on: November 27, 2019, 09:00:45 PM »
Well got my dash LED indicator lamps in the post...tell me what you think
Light blinking vid
I think they will good once every thing comes together.   Grin
« Reply #289 on: November 28, 2019, 04:59:16 PM »
Hey Cam, the link for the video doesn’t open fully, just shows the static photo. Looks good, as you said, once it all comes together it should look great.
camxsmith
« Reply #290 on: April 08, 2020, 07:27:28 AM »
Wow how time flys... getting the 120 days warning ..
Well be doing some time on another project John Deere compact which i picked up for a steel.
Enough on that..  Back to the Car
Been working on the passenger side rear seat floor and inner guard.  Cleaned up all the rust in the rails and treated and paint with KBS and cooper weld thru , ready for the floor.
camxsmith
« Reply #291 on: April 11, 2020, 08:06:55 PM »
Again a few hours spent cutting and welding
« Reply #292 on: April 12, 2020, 10:05:34 AM »
Nice work Cam
Neil
Longman
« Reply #293 on: April 12, 2020, 04:24:33 PM »
Yep, been there, done that. Nice work Can.
camxsmith
« Reply #294 on: May 03, 2020, 06:23:38 PM »
Had to hammer out a new piece for just in front of the seat
Drilled and spot welded in the floor
camxsmith
« Reply #295 on: May 19, 2020, 09:38:36 PM »
Started looking at the front passenger side floor and a pillar
Also made a good start on the driver side rear floor.. I have also put in a new section in the tunnel between the rear floor sections.
also brought a new welder helmet (high recommend) not sure if that helps with the poor welds much.  but now I can see how bad I'm doing.   Grin Grin
Luke Healey
« Reply #296 on: May 23, 2020, 06:47:29 AM »
Great progress.
Sent from my G8342 using Tapatalk
camxsmith
« Reply #297 on: June 26, 2020, 09:34:14 AM »
Some in rear guard work , took off the inner layer to find a lot of rust surrounding the lead seam join.
Made a new piece and weld it in..  Will have to do the other side now I know there is that much rust under there.
Finished inner
Nice new out rigger, will add the new mounts when I perform and engine test fit.   New mounts and out rigger from Pete Mallaby, really nice parts
Luke Healey
« Reply #298 on: June 26, 2020, 07:13:11 PM »
What is the scallop in the outrigger for?
« Reply #299 on: June 27, 2020, 11:22:20 AM »
Maybe for stabaliser bar?
Pages: 1 ... 13 14 [15] 16 17 ... 19   Go Up
