September 05, 2025, 02:43:43 AM *
Pages: 1 ... 15 16 [17] 18 19 ... 60   Go Down
Author Topic: 365 weeks...  (Read 907688 times)
FCGos
« Reply #320 on: April 10, 2011, 07:02:39 PM »
If you want a heavy duty and safe connection for jump starting you can't go past an Anderson Plug, they are safe and neat, handle high amps and you can get them with an incorporated safety cover.  You will need 2 one for the car and one for your jumper leads which you can make out of the same wire you use for the car.
Hope this helps, Cheers Wayne
Ol_Girl_58
getting there...
« Reply #321 on: April 10, 2011, 07:40:23 PM »
Just run a larger cable back to the boot. I used 25 sq mm welding cable for mine as it's plenty large enough and also very flexible.
I'll second that, JB. Does the job well.
« Reply #322 on: April 10, 2011, 11:13:30 PM »
Hmmm,interesting.....You don't need to run an extra cable to the boot.If you use a large (00 size,approximately 75mm2 cable) to your starter motor from the battery in the boot then you only have to run a 16mm2 (overkill) cable to that same terminal from your alternator  Huh .I have done this on my Commodore which has battery in the boot,body as the earth and agree to make sure you clean the area of steel to bare where the earth attaches.No point in having two cables doing the same job....Also no need for fuses/circuit beakers as the cable will only be about three feet long.There were no fuses on the charge cables on original later model cars so why complicate it.Different story if the cable goes to the back.Start cables can't be protected unless you can find a 600amp fuse somewhere.
« Reply #323 on: April 12, 2011, 03:17:55 PM »
Couple of little things tidied up today. The belt for the alternator fitted first time, I had plenty of play in this one though to get it right, could have gone down to the next belt which was 25mm shorter but thought that a better wrap around the pulley was better.
Tried to get the sump off today but it fouls on the front end, so the engine will have to come out to do the sump and the oil pick up... Bugger.
« Reply #324 on: April 12, 2011, 03:21:56 PM »
JB,
That is a tight fit, you did well to get all that in there.
What power steer setup are you going to use?
F4+ Wink
« Reply #325 on: April 12, 2011, 04:49:12 PM »
It was a bit more luck than good management Keith to get all of it in there. I put the motor so far back because I wanted to use the thermo fans out of the Commodore like i did in the van. Because of that decision and only because of that I was able to fit the air cond in the spot that it is in. Otherwise I don't know where it was going to go.
The power steer set up is a VS power steering rack on the V6 conversions front end and obviously the VT steering column, I just have to get an engineer to make the piece that connects the 2 now, and then get the hoses made, but not sure where to get them done yet, I haven't even thought about it.
I think the cruise control unit will need to get mounted next so that I can then start the wiring process again... YUK. But it has to be done.
« Reply #326 on: April 12, 2011, 05:18:46 PM »
I so hate wiring... Good luck with it
F4+ Wink
« Reply #327 on: April 18, 2011, 06:50:58 PM »
Little bit more done today, looks neat on one side but on the other... well.
Starting to fill up in here...
Time to pose a few more questions...
Are pod filters illegal in QLD for rego?
Is the original air sensor contained in the air box essential when now I am looking at a pod filter?
I also have to work out the best way to get the piping for the aircond and the battery cables through the firewall...
« Reply #328 on: April 18, 2011, 07:33:51 PM »
If its like NSW you only need a cover over the pod filter sold at supercheap ect.
In saying that i have never been pinged for not having one at all.
You will need the map sensor  unless you get a mapless tune done.
« Reply #329 on: April 18, 2011, 08:22:56 PM »
Just having a look at the manuals, I am planning on keeping the Mass Air flow sensor, and the other sensor that I was trying to find out about ended up being a Intake Air Temperature sensor. I think that I will be able to incorporate this in the system somewhere.
Hopefully a cover is all that I will need. When the van was registered nothing was said about the bare pod under the bonnet.
GM
« Reply #330 on: April 18, 2011, 08:30:33 PM »
Hey Jason, the van was knocked for the filter for a blue slip, but o.k. for a pink slip. How does that work?
« Reply #331 on: April 18, 2011, 08:34:44 PM »
What's the difference between the blue and a pink slip? I have never registered a car in NSW. In Vic and QLD once registered then that was it for Road Worthy unless pulled over by the police for an inspection, or defect..
« Reply #332 on: April 18, 2011, 08:40:05 PM »
I was told to remove a pod filter by an engineer and fit the factory air box Huh Huh ...Blue slip is for an unregistered car cost $56....pink slip $32 ....FC427....
« Reply #333 on: April 18, 2011, 11:15:02 PM »
Why are pod filters so evil  Huh
« Reply #334 on: April 18, 2011, 11:25:29 PM »
I reckon it just some thing that easy for them to notice that has been modified Huh Huh Huh bit like the cops can defect a modern car that has the exhaust changed from standard if they care to obey every letter of the law  Roll Eyes Roll Eyes Roll Eyes ....FC427.....
« Last Edit: April 20, 2011, 07:52:54 PM by stinky » Logged
« Reply #335 on: April 21, 2011, 07:11:33 PM »
Cleaned up the wires behind the firewall for the engine management.
Jaycar had the cable 0 Guage, which after looking at it would be approx 45mm sq, and still flexible. The only thing that they didn't have was the correct crimp ends that I needed for the starter... Maybe Bursons for these.
« Last Edit: April 26, 2011, 09:15:05 AM by fevanv6 » Logged
Maco
« Reply #336 on: April 21, 2011, 07:36:24 PM »
Try an Electrical Wholesaler for the lugs.
Better in Green
« Reply #337 on: April 21, 2011, 07:39:30 PM »
If the cable is running through the cabin  it's suppose to be double insulated .....easy enough to do with convoluted tubing .......FC427.....
Rusty_T
« Reply #338 on: April 21, 2011, 09:33:39 PM »
 Wink
Jason,
Try Battery World for the crimp ends. They will have them and will most likely crimp them for you. They did a couple of ends for my dual battery set up in the Hilux.
Cheers Rusty.
« Reply #339 on: April 25, 2011, 03:46:48 PM »
Another small step over the last few days, tidied up a bit of wiring harness to look at the pod filter. Made a small bracket for the map sensor and welded it to the alternator bracket. Managed to get the map sensor and the temperature sensor fitted inline also.
Pages: 1 ... 15 16 [17] 18 19 ... 60   Go Up
Page created in 0.053 seconds with 18 queries.
