August 05, 2025, 03:31:01 PM *
Pages: 1 ... 13 14 [15] 16 17 ... 60   Go Down
Author Topic: 365 weeks...  (Read 872906 times)
tuffute
« Reply #280 on: March 24, 2011, 07:42:25 PM »
hope theses help jason if they upload
and the last two are for inspiration
sorry couldn't help my self
thanks brad
« Reply #281 on: March 24, 2011, 09:10:11 PM »
One day mate they will sit side by side!
The alternator does sit in there neatly, now I have to find one.
Purple UDL noted...
« Reply #282 on: March 28, 2011, 03:24:13 PM »
Engineer came over yesterday, down from Townsville to do the Targa Tasnmania. Fixed a seal on his 4wd, then looked at the ute. He had not seen it for about a year and liked what he saw, nothing to redo or re engineer.  Grin Gave me a few more ideas too, but the next time he needs to see it will be when being driven for the final inspection so a very happy camper I am. Continue on I will.  Grin Cool Cool
« Last Edit: March 29, 2011, 07:42:35 PM by fevanv6 » Logged
« Reply #283 on: March 28, 2011, 04:06:28 PM »
That is great! I love the wheels on the "inspiration" ute.
« Reply #284 on: March 28, 2011, 04:08:11 PM »
good stuff JB.
« Reply #285 on: March 29, 2011, 07:21:01 PM »
Here are some shots of the seat belt brackets for Blok.
Spoke to the engineer about the bracket when he was here, they measure 3750mm sq to be legal.
Welded in behind the pillar to look neat, and then under the floor.
GOA350
« Reply #286 on: March 29, 2011, 07:35:17 PM »
That sounds right, i had to do the same for mine.
 Great to hear about the engineer, it makes doing modifications more promising if you want to register it.
BLOK
« Reply #287 on: March 29, 2011, 08:19:42 PM »
Thats great JB just what I wanted your build looks great by the way
FE 4 ME
"A Sweet Sensation"
« Reply #288 on: March 29, 2011, 08:31:18 PM »
what is the thickness of the plates used for the seat belt mounts JB ?
great work by the way
FE 4 ME
« Reply #289 on: March 29, 2011, 08:58:56 PM »
The plates are 7mm x 50mm x 80mm, so the area I had was 4000sq mm.
I have seen some plates that are long and skinny to get the 3750sq mm.
Thanks for the appreciation, but I wish it was further along and at least getting some colour done... One day soon.  Grin Grin
FE 4 ME
"A Sweet Sensation"
« Reply #290 on: March 29, 2011, 09:17:17 PM »
Thankx JB,
     i was hunting around my shed today and i pulled out some pre-drilled plates with rounded edges that do qualify for area coverage being 50mm x 95mm but the thickness is only 3mm...im thinking that maybe the thickness will let me down...im hoping not cause they would do just nice, i have a few of them, but not enough to double the plates up to increase the thickness...
3mm to thin ??
cheers JB
FE 4 ME
« Reply #291 on: March 29, 2011, 09:19:09 PM »
I would say its too thin because you need to be able to get enough depth of thread for the bolt., would you use a 3mm nut to stop you in an accident?
« Reply #292 on: March 29, 2011, 09:33:37 PM »
thicker the better and it has to be 1 piece.
FE 4 ME
"A Sweet Sensation"
« Reply #293 on: March 29, 2011, 09:49:31 PM »
i forgot to mention these are for the floor and pracel shelf mountings, not the pillars, i was going to use HT nuts and bolts to go through the plates...that's the info i got off a installer who does rear seat n belt installs in vans and baby seats... they have the standard plates pretty cheap, but i cant remember how thick they are..i do recall he said the total area of the plate has to equal 3" x 3" in total
does this sound similar to your advise Huh
FE 4 ME
« Reply #294 on: March 29, 2011, 09:57:42 PM »
I am not sure of the thickness you will require for your application, you may need to talk to your engineer about it as any seat modifications require engineering.
FE 4 ME
"A Sweet Sensation"
« Reply #295 on: March 29, 2011, 10:08:13 PM »
Yeah i will he was a nice guy and happy to help
cheers...enjoying watchn ur work...very handy
FE 4 ME
« Reply #296 on: March 30, 2011, 06:14:45 PM »
Its amazing how much fine dust is made from cast steel, I made the mistake a few days ago of not closing a couple of doors to the house and then began work on the air cond bracket. To say I made a mess is an understatement, not to mention the trouble I got into with Nicki.
I bought a second air cond bracket and cut it up to fit the original one that I had, then took 5 hours to cut, grind, weld, and then do it all again to make it fit into the only spot that the compressor will fit. A tight  spot it was too.
Bought a small gas bottle to heat up the cast steel before welding the 2 pieces together, and here is the result.
I just have to weld on the idler to tension the belt and strengthen the bracket some more to stop fatigue cracking at a later stage.
« Reply #297 on: March 30, 2011, 07:12:59 PM »
Hey JB,
The number of posts in this thread is bearing down on the number in the title.
It's bloody inspirational stuff, and a great service you're providing for those who come after you wanting to take on this sort of project on their own.
Keep up the good work.
« Reply #298 on: March 30, 2011, 08:31:08 PM »
Thanks RET, the line of thinking is that there are not too many projects that get shown from start to finish in detail. I guess after reading the build books that showed the progress stage by stage and how helpful they were I thought some guys and girls may like it. Some stuff may not be perfect, but I am just having a crack.
FE 4 ME
"A Sweet Sensation"
« Reply #299 on: March 31, 2011, 11:17:02 AM »
Hey JB what build books are you talking about that you have ? be good to have something in book for to gain further skills and knownldge
thankx for taking the time to share and show this to the rest of us...it's been very helpful
kepp up the high quality work
"Have a Great Holden ( FE ) Day !!! "  Cheesy Cheesy Cheesy
FE 4 ME
Pages: 1 ... 13 14 [15] 16 17 ... 60   Go Up
Page created in 0.084 seconds with 19 queries.
