July 18, 2025, 11:57:10 AM *
Author Topic: Horn Position  (Read 2868 times)
Rod
« on: June 16, 2021, 06:52:04 PM »
Hi All,
I am in the process I putting the wiring loom and little bits and pieces back together with my FE. I did take many photos of before but one I didn't was the position of the horn. Now when I have reinstalled it after a lick of paint, the wires don't seem to be long enough. Please see photos below.
I am not sure what I have done. Does anyone have a photo of the position of the horn I can compare to?
Thanks in anticipation.
Cheers Rod
« Reply #1 on: June 16, 2021, 07:26:28 PM »
Looks like it should be rotated around to put the screws underneath where the wires currently are. Have you had the two halves of the horn apart?
Rod
« Reply #2 on: June 16, 2021, 09:52:20 PM »
Hi Ken,
Thank you. Gee it has been some time since I gave the horn a coat of paint. If my memory serves me correctly, I think I did pull the horn apart for a clean and then paint. I will investigate if I have put it back together incorrectly.
I did a quick 180 degree turn as shown below and now the terminals are on the other side and line up with the leads ok. But it doesn't seem right. ie: the horn seems to be forward too much (won't know fully until I put grill in) and the main body of the horn is now not in the recessed section of the radiator cowl (I hope that makes sense).
Thanks again Ken. I will dismantle and see if I can get it aligned properly.
Rod
my8thholden
« Reply #3 on: June 17, 2021, 08:11:58 AM »
Hi Rod ..I had the same problem when reassembling my FC sedan , I wish I could remember exactly ,but my vague memory tells me I had the mounting bracket on wrong way around ,i do recall like you it was a mystery till the penny dropped and then it was straight forward..hope that is it ..Vern .
« Reply #4 on: June 17, 2021, 09:51:16 AM »
The dome goes the way you had it originally. I think the horn body needs to be rotated on the horn base. It’s hard not having a horn here that I can play with.
Rod
« Reply #5 on: June 17, 2021, 09:00:27 PM »
Hi Ken and Vern,
Thank you! As it turns out, the internal horn body was out out by one hole if that makes sense. Thanks Ken for the heads up. I had to rotate it one hole clockwise and I think I am in the right spot now, even though there isn't much room for error in the length of the wires.
A huge shout out to Gary for emailing me some photos of a couple of horns which showed the correct position. Thanks so much.
Cheers Rod
my8thholden
« Reply #6 on: June 18, 2021, 08:13:13 AM »
Thanks Rod ,penny dropped again..Vern
« Reply #7 on: June 18, 2021, 08:58:43 AM »
Good stuff Rod, sometimes it’s hard to explain in words what you can picture in your mind…..
Page created in 0.05 seconds with 16 queries.
