July 18, 2025, 03:58:06 PM *
Author Topic: Steering column wiring  (Read 7578 times)
muzzie
« on: January 06, 2014, 10:13:12 PM »
G'day, out of my steering column i have drk blue, lght blue, yellow pink, white, tan and violet. Found out where they all go apart from pink, white and violet. Cany sugestions? Thanks muzzie
DJ
« Reply #1 on: January 06, 2014, 10:27:05 PM »
0417 270 315
muzzie
« Reply #2 on: January 07, 2014, 06:31:11 AM »
Thanks Dave, I have got this wiring diagram just cant work out what they plug into, the violet, pink and white all go to the same place as the drk blue, lght blue and the tan but i cant find anywhere under my dash for them to go. Where the drk blue wire plugs in there is a double terminal and the same with the lght blue but only one of each are being used. Would they get their power from these? if all that makes sense? Thanks Muzzie
« Reply #3 on: January 07, 2014, 07:10:15 AM »
Sometimes the search functions works  Tongue
This might help
http://fefcholden.org.au/forum/index.php/topic,15607.msg93785/topicseen.html#msg93785
« Reply #4 on: January 07, 2014, 08:10:56 AM »
I  can help if necessary . I got pulled up one night by the police to explain why my FE tail lights were flashing on one side and staying on the other as I turned .What the ? Haydn
FC Dave
« Reply #5 on: January 07, 2014, 09:32:17 AM »
White goes to brake switch. Pink & violet are rear blinkers. the two blue are front. yellow, power in. another pink from ing to flasher can. I am sorting mine out now. Doing some re-wiring as I have added separate blinkers to the rear of my 58. Forgot to mention, two other blues are for dash lights. Dave
« Reply #6 on: January 07, 2014, 10:29:05 AM »
From steering column
White - brake light switch single connector
Dark Blue - Double connector to RHF indicator & LH tell tale light
Light Blue - Double connector to LHF indicator & RH tell tale light
Yellow - flasher can single connector
Pink and Violet - go to rear indicators, there should be 2 single connectors coming from wires in the A pillar
Tan is a separate wire which is the horn
muzzie
« Reply #7 on: January 10, 2014, 03:54:28 PM »
Thanks all, ive hooked them all up everything works fine until i turn my tail lights on then when i put my indicator on its not the clear lense what flashes its the tail/brake light which flashes. Bad earth or is this correct? Thanks Muzzie
« Reply #8 on: January 10, 2014, 04:54:41 PM »
This is correct, It should be the brake light flashing regardless of whether you have the tail lights on or not.
muzzie
« Reply #9 on: January 10, 2014, 05:36:52 PM »
so what are the clear lenses for? reverse lights? Thanks Muzzie.
« Reply #10 on: January 10, 2014, 07:16:12 PM »
Yes optional reverse lights. This all changes in September 1959 when the lower lenses change to orange and the blinkers move to the lower half of the tail light.
muzzie
« Reply #11 on: January 10, 2014, 08:23:20 PM »
so if i havent got reverse lights the clear lenses do nothing? the red lense is brake, tail and indicator? does it just take a double element globe? Thanks Muzzie.
« Reply #12 on: January 11, 2014, 09:01:43 AM »
Yes double element globe, the brighter filament is Brake / indicator and the duller filament is tail lamp.
muzzie
« Reply #13 on: January 12, 2014, 06:39:18 AM »
too easy, all fixed. Thanks for that. Muzzie.
Page created in 0.034 seconds with 17 queries.
