May 21, 2025, 01:13:58 AM *
Author Topic: cylinder head part numbers  (Read 5565 times)
walks
« on: January 01, 2013, 01:31:45 PM »
Hi all,
          Can anyone tell me if the cyl head I have on my engine is the correct one, as when I bought the car it came with the engine in pieces and was told it was a 138 bought as a replacement when the original engine block cracked. The engine (minus the head and flywheel) I have since discovered is from an FX. The part number cast on the head is 7412811.
Thank you
Walks
WALKS
« Reply #1 on: January 01, 2013, 01:42:16 PM »
The FE FC head should not have a water jacket hole at the front for the heater outlet. It should have an outlet at the back only for the temp sensor.
walks
« Reply #2 on: January 01, 2013, 01:55:37 PM »
Thanks Ken,
                     Mine has a hole at the front and a hole at the the back with a plug fitted.
Walks
WALKS
« Reply #3 on: January 01, 2013, 04:40:29 PM »
From my understanding this would make it a later head from FB to EJ. I have 2 heads here with the single outlet and both these have 7412811 part number as well. There is a date code cast into the top of head near the part number - can you make this out?
walks
« Reply #4 on: January 01, 2013, 07:31:31 PM »
Ken,
        I'll have a look tonight and let you know.
Walks
WALKS
walks
« Reply #5 on: January 02, 2013, 01:32:19 PM »
Ken,
        The number that is next to the part number is D 121. Also as I had to remove the cylinder head I was able to confirm that the engine is a 138 as it has p/n 7406476 pistons fitted. The engine block s/n is 116656 & p/n 7400479.
Walks
WALKS
« Reply #6 on: January 02, 2013, 04:14:47 PM »
Walks, I assume the engine number starts with a B. that is B116656, this indicates a FB/EK block.
The casting number indicates the head was made April 12, 1961.
walks
« Reply #7 on: January 02, 2013, 05:29:52 PM »
Ken,
        There is no prefix to the engine number. I can only assume that at some point it has been bored to take the larger pistons.
Walks
WALKS
« Reply #8 on: January 02, 2013, 09:05:50 PM »
If there is no prefix then it is a FX/FJ block.
Page created in 0.044 seconds with 16 queries.
