July 18, 2025, 04:43:31 PM *
Author Topic: What is it?  (Read 6937 times)
Martin
« on: May 07, 2012, 01:56:25 AM »
It's obviously a drift to insert a threaded component which is screwed on at one end and whacked at the other end to drive it home.  It was included with some other tools I bought several years ago.
Stamped   "Dufor 3"
So, what does it fit?
Thanks,
Martin
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
« Reply #1 on: May 07, 2012, 06:23:03 AM »
It looks like an end that is used in the building industry for threadrod, either to join sections or to do as you say use as a drift.
« Reply #2 on: May 07, 2012, 09:13:31 AM »
G'day Martin,
Looks to me like a Dufor stud extractor, size #3 in a series of about a dozen. I can't find my Dufor tools info, but pictured below is the same gear from Coxhead. Looks lilke your stud extractor collection is like mine... I have a lonely Coxhead #1  Grin.
Harv.
Martin
« Reply #3 on: May 07, 2012, 12:01:07 PM »
Thanks, gents.
It's not hollow thoughout - so if I inderstand "threadrod" correctly, that is ruled out.
Harv could be right - althouigh I still think it's for whacking.  Here's another pic showing the "whacking" end.
Martin
Martin
Marion.  South Aust.
Martin
« Reply #4 on: May 07, 2012, 12:15:04 PM »
I meant to add,  I don't have anything large enough to try it out on, but internal diameter is 0.786 inch =  roughly 3/4 or 13/16.  Depth of thread is 0.712 inch - nearly 3/4"
Martin
Martin
Marion.  South Aust.
fastjbav6
OK start her up !
« Reply #5 on: May 07, 2012, 01:40:35 PM »
Its a tool for removing/fitting the upper/lower control arm pivot shaft that's screwed in the cross member.
I borrowed one from Shacks Holden in Fremantle when restoring 2BRITE.
Kind regards
Seb
Scrutineer
FE-FC Holden Car Club of WA (Inc)
Yellow Knight
Martin
« Reply #6 on: May 07, 2012, 05:27:03 PM »
Thanks Seb.  That makes sense.
See it on Parts For Sale soon.
Martin
Martin
Marion.  South Aust.
« Reply #7 on: May 07, 2012, 09:34:56 PM »
Gents,
I could be way, way wrong (and often am  Embarrassed), but I understand the control arm shaft remover and replacer (3A4) looks like this:
(this is the Litchfield version, E1882). This allows you to screw the upper and lower control arm shafts in and out. It looks to have a thread of 3/4-10 UNC.
The tool Martin has is designed to screw onto something, then belt the snot out of it ( Grin), kinda like the wheel bolt peening drift (tool 3A7) or crankshaft balancer replacer (6A2). The thread dimensions are similar to the 3A4, but look closer to 7/8-9UNC.
Again, I could well be wrong.
Harv.
Martin
« Reply #8 on: May 08, 2012, 12:07:25 AM »
So the ball's back up in the air again.  At least Litchfields stamped the GMH number on the applicable tools.
Anybody else got any ideas?
Martin
Martin
Marion.  South Aust.
