July 18, 2025, 08:13:15 PM *
Author Topic: Help  (Read 3759 times)
spider
GO THE MIGHTY GREY MOTOR
« on: February 08, 2003, 11:53:21 PM »
 Smiley
Hi to All,
            Does anyone know if hk holden brakes bolt straight on to hr disc front-end Huh Huh. I went to get some new disc pads and the only ones that matched was HK Holden Huh Roll Eyes.Has anyone else come across this setup.
Cheers Spider Cool
« Last Edit: February 09, 2003, 05:47:35 AM by spider » Logged
Effie C
Still Lost & Confused
« Reply #1 on: February 09, 2003, 06:48:20 AM »
G'Day Spider
I have read on another site,I think EH, that they do indeed bolt on but the HR wheels won't fit must use HK or variation there of.
Hope this helps
John M
FC2104
« Reply #2 on: February 09, 2003, 09:54:52 AM »
SPIDER
I HAVE HT DISCS FITTED TO MY FC THEY BOLT STRAIGHT ON BUT YOU DO HAVE TO CHANGE TO 14" WHEELS. THE HK,T,G  STEERING ARM IS LONGER THAN HR  AND WILL GIVE A SMALL AMOUNT OF BUMP STEER .I PUT THE HR STEERING ARMS ON TO THE SPINDLES TO KEEP STANDARD GEOMETRY THEY ARE THE SAME BOLT PATTERN
DEAN
« Last Edit: February 09, 2003, 10:00:11 AM by FC2104 » Logged
spider
« Reply #3 on: February 09, 2003, 11:14:12 AM »
 :DThanks Dean and John M,
                                      I am glad i have found that out. Dean my 13 inch chromies bolted on, just had to grind a couple of thou off in certain areas where the wheels were hitting the callipers.
Cheers Spider Cool
« Last Edit: February 09, 2003, 11:15:14 AM by spider » Logged
FC2104
« Reply #4 on: February 09, 2003, 12:09:54 PM »
NO PROBLEM SPIDER GLAD TO HELP
DEAN
« Reply #5 on: February 10, 2003, 10:16:53 AM »
Spider I have to say that you put yourself in great jeopardy by grinding the calipers.
This is very unsafe as you would be amazed how much a caliper flexes under load.
I currently work in a brake shop where we do big brake conversions and we have also fixed other peoples creations including ground down calipers which have broken with very exciting consequences.
spider
« Reply #6 on: February 10, 2003, 11:16:17 AM »
 :)Hi Ken,
               The amount that came off was approximately 1mm, i also took them down to the local brake shop to show them what i had done, to check if it was safe and they said there would be no problem. The measurement between the top of the caliper to the bolt holes is 9mm, so there is still alot of meat there. But thankyou for your concern, it is much appreciated Smiley
Cheers Spider Cool
Page created in 0.118 seconds with 17 queries.
