July 18, 2025, 03:58:10 PM *
Author Topic: Sump  (Read 4882 times)
spider
GO THE MIGHTY GREY MOTOR
« on: January 18, 2003, 02:02:46 AM »
Hi All,  Smiley
I was told that i could use any sump up to hg Holden for the 186 to hr front end is this true Huh
Cheers Spider
« Reply #1 on: January 18, 2003, 02:10:34 AM »
No.  If you've got standard HR front end you need an EH sump and oil pickup (ie from 149 or 179).  The shape of later red sumps doesn't suit.  Your other option is to make it fit with oxy and welder  :-/
slim
« Reply #2 on: January 18, 2003, 02:27:39 AM »
Yes RET is correct Eh is the one you need!
Im located at Liverpool, NSW
spider
« Reply #3 on: January 18, 2003, 03:36:07 AM »
 :)Thanks Fella's, Much appreciated. Slim any idea when you will have one as it is the only thing stopping me from putting in the motor. The red motor original sump that was with the red motor was cut and shut and it looked like a dry sump setup, it was a abortion.
Cheers Spider
Jockster
« Reply #4 on: January 18, 2003, 06:41:44 AM »
Spider
From memory you can also use an LC-LJ Torana sump, I put an XU-1 engine straight from a Torana into an EH about 15 years ago and I am positive we did not change the sump.
Jockster Grin
mike
« Reply #5 on: January 18, 2003, 11:06:24 AM »
Hi Spider, looking at a LC/LJ torana sump I cannot see why one wouldnt fit it only has 2 steps compared to an EH sump which has 3, the torana sump is shallower in the crossmember area more so than even the EH also this is where the other red motor sumps will hit the FE crossmember. So comparing the two side by side here I think the torana one would fit.
regards mike.
brads59
OLD OLDENS=STYLE
« Reply #6 on: January 19, 2003, 11:19:15 PM »
Not sure about LC/LJ sump into HR front though.
Cheers.... BRAD
1959 Black Std sedan
slim
« Reply #7 on: January 20, 2003, 07:48:28 AM »
Contact Tony on 0407668793 , he has the eh sump and pickup I spoke of
spider
« Reply #8 on: January 20, 2003, 11:02:12 AM »
 Cheesy Hey Slim,
Thanks for that. I will ring him tommorrow, i forget that we dont have daylight saving. So it will be to late to ring him tonight.
Cheers Spider Cool
Page created in 0.03 seconds with 18 queries.
