July 13, 2025, 04:42:27 PM *
Author Topic: seat surrounds  (Read 9727 times)
Jonno
« on: October 13, 2005, 06:18:26 AM »
Here are some photos of FE vs EK seat surround mounts, in response to this thread in 'Parts Wanted' (I thought it more appropriate now in this section):
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=pwntd;action=display;num=1128921577
I should start by saying that I 'think' my FE seat is an FE seat. I was a little confused by the fact it has a rear ashtray mount and I have a ute....but folks seem to think this in just a mass produced item. Anyway, as far as I can tell, the only difference between the two is that the EK seat is about 4cm lower in height and has slightly different mounts for the seat surrounds.
The front mounts are identical:
The rear corner mount is slightly different:
and the mounting point on the rear vertical is in a slightly different place:
All you would need to do to fit a metal EK surround to an FE/FC seat would be to grind off the tab 'A', fabricate a tab 'B', and then add an extra plate on the vertical to screw into. Here is the EK surround fitted:
hope this helps.
Jonno
« Last Edit: October 13, 2005, 06:25:31 AM by Jonno » Logged
Cottles Bridge, VIC
craiga
« Reply #1 on: October 13, 2005, 07:17:35 AM »
Great post Jonno.  VERY helpful, and much appreciated for the quality and content.
Craig.
Jonno
« Reply #2 on: October 13, 2005, 07:55:00 AM »
thanks Craig,
I should probably add that I haven't actually DONE this mod myself as I'm thinking about using the entire EK seat set-up. But I have looked at both fairly closely...and can't see any reason why it wouldn't work fine.
Jonno
Cottles Bridge, VIC
20.4_seconds
The ox is slow, but the earth is patient!
« Reply #3 on: October 13, 2005, 08:48:31 AM »
Cheers Jonno,
Clear and detailed and great pics too...I knew about the front part and was hoping to find out about the rear without too much investigation...thanks so much Jonno...great work dude...
Nick
All I  want for Christmas is a Smiths clock bracket and knurled knobs
Sarge
« Reply #4 on: October 15, 2005, 08:30:30 AM »
Jonno
       Thanks for the heads, up as I am fitting EK metal surround to the FC seat. Now I know to do the tab before it goes to the trimmers.
Sarge
        0421 165 351
Roybeth
« Reply #5 on: November 20, 2020, 07:45:27 AM »
Jonno
Sarge
Hi Guys - think this may be the thread I was looking for? but of the course the pics are not available anymore  Sad
Roybeth
« Reply #6 on: November 22, 2020, 09:17:10 AM »
Here's the project, from the tabs on my seat seems the metal surrounds are not as wide along the seat edge where the tabs are. Some have suggested removing or shortening these tabs and screwing into the frame at the back top edge.
126372441_209375907237615_8179032132094247124_n by Helen Sheedy, on Flickr
Roybeth
« Reply #7 on: November 22, 2020, 09:18:13 AM »
Heres the front tab of the seat
125883051_1519765788214529_9133323997448378977_n by Helen Sheedy, on Flickr
Roybeth
« Reply #8 on: November 22, 2020, 09:21:42 AM »
and the back, which I imagine will be the one I will modify - have to more precisely check out the fit of the front tab to the metal surround in case both will need to be done.
125545419_284802776267638_128672697081424616_n by Helen Sheedy, on Flickr
