July 26, 2025, 05:41:02 PM *
Pages: [1] 2   Go Down
Author Topic: hq-hj,hx,hz stubs, same???  (Read 16104 times)
ekolden
« on: September 12, 2005, 01:58:52 PM »
"HI"I have a hr front end in my ek ute, and what i would like to know is hj,hx,hz stub axles the same as hq ones, that will lower the front by 1".or even will they "fit", the hr ? thanks.
FB_MAD
« Reply #1 on: September 13, 2005, 07:01:45 AM »
From memory the HQ front stub axles are the same as HJ,HX and HZ but don't know about the lowering bit you asked about.I've never done it but I suspect that the HQ-HZ stubs may fit HR but I'm sure someone out their will correct me if I'm wrong.I'd give Rod Hadfield at Castlemain Rod Shop in Victoria a call as he has been fiddling and making all sorts of conversions over the years and I'm sure you will get all the info you need. Good Luck, Terry.
Has anybody seen my red pen??
« Reply #2 on: September 13, 2005, 07:28:19 AM »
The HQ stubs give a 1 inch drop, not sure about being the same as the later stubs though.
The Sept '05 edition of Aust Street Rodding has a full comparo of the holden stub axles and CRS stubs on holden front-ends
ekolden
« Reply #3 on: September 13, 2005, 07:56:44 AM »
 "Thanks for the info, but i might wait to see if any body on here knows first before annoying them.it's just i can get hold of some hj/hz stubs, rotors and callepers.and hopeing they fit up the same as hq's with the 1'drop.
GM
« Reply #4 on: September 14, 2005, 07:52:47 AM »
I have WB stubs fitted to my HR frontend. HX should be same. [approx. 20mm drop]
                               Cheers Glenn
« Last Edit: September 14, 2005, 07:56:13 AM by Glenn_m. » Logged
ekolden
« Reply #5 on: September 14, 2005, 08:14:29 AM »
"thanks glenn" and would you know! weather hg hubs will go on them.thanks.
« Reply #6 on: September 15, 2005, 07:52:22 AM »
All stubs from HK to WB are the same, will fit into a HR with the correct steering geometry and will lower the car a bit less than an inch.
Rod Hadfield hasn't been at CRS for over a year and the new guy has just left as well.  Currently being staffed by some of the backroom guys.
The Australian street rodding article has so many errors it is not funny - we have written a response to ASR but who knows if it will get printed.
GM
« Reply #7 on: September 18, 2005, 07:03:46 AM »
HG hubs will fit but they will look like cheese cutters compared to the HZ rotors.
                      Cheers, Glenn
« Reply #8 on: September 18, 2005, 07:37:12 AM »
There is only one good reason for fitting HG brakes to the front end, and that is because they have early stud pattern!
HQ to WB brakes, although better, will require running HQ rims which wont match the HR rear end.
There are ways round this by having blank HQ rotors drilled to early stud pattern but these are expensive.
Have I assumed correctly ?
SRVLIVES
« Reply #9 on: September 18, 2005, 07:51:37 AM »
I was just going to post on this very subject.
As one of my front discs needs replacing, will HKTG discs fit my HR front end?
Also, are FC rear drums really that fragile? Mine look like if you hit them with a hammer you'll punch a hole right through!
What drums will fit my rear end? Depending on my diff ratio (I may replace it) would it be easier to replace the whole rear axle assembly?
ekolden
« Reply #10 on: September 18, 2005, 09:37:14 AM »
spot on ken" i thought if i use hq-wb stubs  with the hz alloy callipers,(hg hubs and rotors won't match up with hz callipers?) if thats the case looks like its the re-drilled ones, any idea on price to re-drill them?, and with the hz hubs do they widen the track any?what i'm trying to achieve is eventually a 2" drop by using the hz stubs(1"- and another 1" off a new set off standard springs;(don't like the h/duty 2"lowerd ones,(to-stiff) "aha" the things we do for just an extra 2". Grin--------cheers.
fcstationsedan
« Reply #11 on: September 18, 2005, 10:04:14 PM »
HQ-HZ should all be the same stubs but HQ had cast iron calipers where the rest had alloy. You should be able to buy new blank HQ-HZ rotors from Hoppers Stoppers and they can drill them any pattern you want, including FE-HG but you must run 14" wheels minimum.
Former 1959 FC Station Sedan owner.
SRVLIVES
« Reply #12 on: September 19, 2005, 02:01:22 AM »
Can anyone ID Dave's 'Station Sedan' for me? Tongue Smiley
Shayne
Just Cruisin'
« Reply #13 on: September 19, 2005, 06:02:55 AM »
57 Chev.
« Reply #14 on: September 19, 2005, 06:36:09 AM »
No HG rotors won't run with HZ calipers.
HQ rotors drilled from blanks are not really cheap - about $180 each.
SRVLIVES
« Reply #15 on: September 19, 2005, 06:41:33 AM »
57 Chev.
Yep.... was just a silly joke....  Embarrassed
fcstationsedan
« Reply #16 on: September 23, 2005, 08:49:49 AM »
It used to be an FC but Stinky bought it from me and this is the replacement 57 Chev 210 4 dr wagon (with Belair strips). I am still into FC's just don't have one at present!
« Reply #17 on: September 23, 2005, 09:32:35 AM »
SRV, the HG rotors will fit on the HR stubs, but the calipers wont go on.  In order to run HG brakes, you need to replace the HR stub axles with the later ones.
SRVLIVES
« Reply #18 on: September 23, 2005, 10:10:55 AM »
thanks Ken, have purchased some Torana ones from Smithy to get me through.... seems the passenger front on my FC was run without the wheel for a bit and worn a big flat on the disc! Sad
fastjbav6
OK start her up !
« Reply #19 on: October 08, 2005, 03:12:24 PM »
All stubs up to WB & Torana will fit the HR front end.
They all have the same tapper on the ball joints.
HZ & WB stubs have a different KPI angle giving lighter/easier steering on the original car.
Remember Radial Tuned Suspension badge on the HZ.
Torana stubs should not be used as often been read due to the Ackerman principle from memory. (steering angle on turns?)
As for fitting rotors, i would fit the rotor and caliper that suits the stub along with the rim. AS long as the rear rims are the same as the front.
Fitting HQ on, Torana or HK discs will change the front track measurement compared to the HR track.
Disc thickness and diameter are different.
I have disc rotor measurements of HK & Torana to compare to the HR if you like.
This will tell you how far out your track would be.
Hope this helps you out.
Regards Seb
Yellow Knight
Pages: [1] 2   Go Up
