August 22, 2025, 07:41:10 AM *
Author Topic: FE Trimatic  (Read 5308 times)
Liam Moloney
« on: May 22, 2002, 09:53:24 AM »
I was wondering if anyone has put a trimatic up against a 138.
If so what mods were needed.ie.  Bellhousing, which pressure plate to use.
Thanx Liam
« Reply #1 on: May 22, 2002, 10:47:39 AM »
Hey Liam,
Are you also planning to fit a supercharger Wink
« Reply #2 on: May 22, 2002, 11:38:33 PM »
With enough money, time and motivation you can do just about anything, no matter how crazy.  Apart from simply proving it could be done, why would you want to do this?
Having said that, you'll need serious floor and tunnel mods, which could well lead you to an engineer.  A trimatic will certainly bolt up to a 138 red, and will probably fit a grey - after all, you can bolt a red to a grey crashbox, so it's feasible to bolt a grey to a red slushbox I suppose  Grin
You won't need a pressure plate, though  Huh
Before spending any money on this venture, see if you can get a ride in an original EK or EJ automatic.  Not exactly a performance powerhouse, are they?  :-/
PS I have fitted a 186/powerglide combo to my FE, so I have some experience in this area.  I like it, but I wouldn't do it again.
Liam Moloney
« Reply #3 on: May 23, 2002, 08:24:10 AM »
Hi all
the reason i wanted to put the 138 back in is becouse i have a 173 in now with a trimatic and all the tunnel and chassis kit has already ben done and registered. I want the car on the road as soon as possible so if i put the 138 back in, i wont need an engineers report just yet and then i wil be able to put all the things like 2 speed wipers, dual circuit brakes in as i go along then put the 173 back in and get it engineered later on down the track>
Liam
« Reply #4 on: May 23, 2002, 09:39:08 AM »
The only thing you haven't figured is that the red has side engine mounts and the grey doesn't.
Also the Trimatic doesn't have side mounts.
You can't mount an engine/trans combination on the strength of a grey front mount and a Trimatic rear mount, it just wont work!!!!! Shocked
4hammers
« Reply #5 on: May 23, 2002, 04:32:11 PM »
Give them a call at "Castlemaine rod shop".
I asked a similar question, & after getting the piss taken out of me for wanting to modify a "Shitty Grey" & "Why don't I get a real motor" (His words, NOT mine!!), I eventually got the info I wanted.
There IS a Tri-Matic to Grey motor adaptor, which I think has the Grey mounts attached.
Hope this helps,
4hammers
« Reply #6 on: May 23, 2002, 11:18:52 PM »
Fair enough.  I guess cruising around with the grey+trimatic combo for a while should be all the incentive you need to put a red in  Grin
Having said that, the body mods you have done might require an engineer's report before you can get it registered anyway, regardless of engine.  I suggest you check before spending any more money on a stop-gap solution.
Page created in 0.03 seconds with 17 queries.
