August 21, 2025, 12:44:55 PM *
Author Topic: DIFF  (Read 4395 times)
demon
« on: April 26, 2002, 08:36:37 AM »
Can you use the HR diff housing and bolt it to the fe ute springs using the hr 4 bolt plate or do i have use the u bolts Thanking you Demon
Digger
Classic not Plastic
« Reply #1 on: April 26, 2002, 10:50:31 AM »
Hi Demon,
You can mount the housing either way but  if you are going to lower the car using lowering blocks you will need to use the U bolts.
Hope this helps
Steve
FC-V8
Not enough hours in the day
« Reply #2 on: April 26, 2002, 07:05:05 PM »
Hi Demon
        The HR housing will fit with its original 4 bolt plates but a couple of things to remember are the HR diff has different uni joint,& the the flexable line for the brakes is a different thread but you can get a adaptor,& the hand brake cable is also different, (i used the HR one)
If you are going to run a HR disc front end make sure your HR diff has 9/16 wheel cylinders as they are different to the drum brake front.
0401-065-201
Page created in 0.042 seconds with 17 queries.
