August 21, 2025, 10:04:43 AM *
Author Topic: Front end red motor  (Read 4635 times)
demon
« on: April 22, 2002, 09:24:53 AM »
HR front end would anyone known how far back the engine mounts need too be welded and what height .Thanking you for your help. Demon
« Reply #1 on: April 23, 2002, 01:05:58 AM »
demon,
It's pretty much a case of swapping them front-to-back, exactly opposite their previous positions.  You can find an article about it here: http://www.fefcholden.org.au/techinfo/tech002.html
sgo
« Reply #2 on: April 23, 2002, 08:22:48 AM »
You can allways drop the motor etc in, make sure it clears everything and tack the mounts in place, lift out the motor and then fully weld in the mounts.
« Reply #3 on: April 23, 2002, 09:39:12 AM »
The important thing is to get the top of the carburettor level.  Since the rear mount is often hand fabricated, the height of the front mount should be set once you have the engine in place on the rear mount.  Level the carburettor.
Similarly the rear position of the mount can be determined by pushing the motor back as far as possible (allowing clearance around the accelerator linkage) this gives maximum room for the radiator.
More room can be achieved by having a cable accelerator.
Tack the mounts once you are happy with both the above.
Finish welding after removing the motor.
Page created in 0.03 seconds with 17 queries.
