August 25, 2025, 08:49:23 AM *
Author Topic: station sedan rear belts  (Read 4140 times)
FC-V8
Not enough hours in the day
« on: April 16, 2002, 09:47:31 PM »
advice needed in fitting retractable seat belts to the the rear corner positions of a station sedan as there doesn't seem to be a suitable position for the top pivot bolt due to the screw on plate between the back door & the side window.so if anyone has worked this out or seen it done please let me know because it driving me nuts.
0401-065-201
FE_225
« Reply #1 on: April 16, 2002, 10:16:22 PM »
The retractable rear seat belts out of a HX Caprice don't have the top pivot point. The reel bolts to the parcel shelf and the bottom anchor point bolts to the front of the wheel well, there is no middle pulley or pivot. I'm not real familiar with the rear of the wagons, maybe you could use those somehow???
Hope this helps
Tony
« Reply #2 on: April 17, 2002, 02:07:37 AM »
Hey Glenn,
How did you go with the demister?
For those of you looking for ducting hose, i saw a hose with 32mm ID at the pool shop, looks like kreepy krawly hose.
back to the seatbelts..
u need a reinforcing or spreader plate behind the bolt (45mm x 65mm x 3mm thick at a minimum) im not sure of the pillar can accomodate this?
anyway if it can, i was going to try sliding a plate up the inside of the pillar with a nut welded to the back of it, then plug welding the plate into place.
The cover on the pillar shouldnt be a problem since the sash guide bolt should be mounted on a spacer anyway to allow free rotation of the sash guide.  Cut a hole marginally larger than the spacer and sit it around the spacer.
My concern is the angle of the belt from the sash guide to the inertia reel.
Does an inertia reel work effectively at all angles?
Will you mount the reel on the wheel arch?
May have to check out some wagons for ideas..
I may try for a hidden installation of the sash guide bolt for the front belts too.
If anybody has inertias in their ride, how did u mount your reel?,, through the floor?
sorry if i had more questions than answers..
Page created in 0.021 seconds with 16 queries.
