May 24, 2025, 12:29:49 PM *
Author Topic: Mounting to fix HR front end outrigger to an EK  (Read 3241 times)
EKman
I'll be a happy man once I get her on the road
« on: April 21, 2005, 01:04:39 AM »
Hi Guys,
This EK with an HR front and rear end, 202 and 3 speed crunch box off the original 138 is my 1st project
Rare spares tell me that they cannot help with the outrigger mounting. Is such a mod available and is it something that will just bolt on or is welding required?
Also, any ideas where I can get a rear handbrake cable guide/mounting. I assume this will be a duplicate of what is used on an HR.
As these questions have probably been asked before, how can I easily find information on a previously discussed topic, within this forum?
Any advise/help would be greatly appreciated
Below I attempted to attached a pic of how the outrigger is currently fixed, but it does not seem to have worked
"F:\Data\Photography\EK\arm.jpg"
Paul
TorqueFC
Modified?
« Reply #1 on: April 21, 2005, 02:20:43 AM »
hey paul
send me any pictures you want put onto the forum, and ill put them on for you
email: kenkanifff@hotmail.com
torque
ps: there are other alternatives to this but here it goes
castlemaine rod shop sell a changeover hr front end set up for ek, what they do is re make another front sections which is about 1 1/2 inches upwards, which means that it meats up to the front end mount properly, also i believe you get papers with it
i wil check out the price just in a tic and get back to you
« Last Edit: April 21, 2005, 02:28:21 AM by torquefc » Logged
TorqueFC
Modified?
« Reply #2 on: April 21, 2005, 02:31:41 AM »
P.O box 349
castlemaine 3450victoria
australia
phone:5472 2853
fax:5472 1241
email:rod@rodshop.com.au
website:www.rodshop.com.au
in 2004s catalogue the changeover front end was $275, but the company has now changed hands so i am sure prices would have increased a little
earlyholdenfan
« Reply #3 on: April 21, 2005, 04:34:56 AM »
Paul, on the top of the forum header, third in from the left is the search icon,  follow the prompts and you will find all you need there, check by keyword, topic or author, Good Luck
Matt
TorqueFC
Modified?
« Reply #4 on: April 24, 2005, 09:52:40 AM »
hey paul
any luck with that problem? did you have any luck with the search engine?, did you ring the rod shop?
hope the info i gave you was helpful
torque
EKman
« Reply #5 on: April 25, 2005, 11:48:48 PM »
Thanks for the info guys
A c/o HR crossmember modified with an EK outrigger will cost $250.00 from CRS. Rare Spares can also supply for $260.00
As I would rather not go through the pain (& cost) of replacing the crossmember, is there a "bolt-on" legal solution, which will allow fixing the HR outrigger, to the EK subframe?
Remember that  the HR outrigger currently sits 60 mm away from the subframe which it should be bolted to?
Paul
sgo
« Reply #6 on: April 26, 2005, 12:11:57 AM »
Why not fabricate you own outrigger and weld it to the crossmember while its all in the car?
« Reply #7 on: April 26, 2005, 09:42:28 AM »
The simple solution is to remove the original HR outrigger and get a FB, EK, EJ or EH outrigger and weld onto the HR.  It fits perfectly and bolts to the original crossmember mount.
Handbrake cable is made by disassembling the EK and HR cables.  Remove the plug ends from the HR cable that go into the backing plate, cut off the ball on one end of the EK cable and fit the HR plug ends to the EK cable ends.
Punch the wire out of the removed ball and then silver solder the ball back onto the cable.  The 10 mm shorter cable wont make any difference to the cable.
If you have trouble understanding this then give me a call and I will explain in more detail
Regards   Ken
