August 31, 2025, 03:13:39 AM *
Author Topic: What's the Diff.  (Read 2092 times)
griffo
« on: November 10, 2004, 04:07:05 AM »
Could someone tell me how to identify the Diff size & the rear running gear set up?
I'm not as smart as your average Bear.
Griffo.
« Reply #1 on: November 10, 2004, 09:48:59 PM »
Presuming it's an early Holden style diff, the ratio is engraved on the edge of the crown wheel, as well as a part number.  If you cannot find a number, it's a 3.89 diff.  Why? Until Holden introduced a different ratio diff in '62 there was no need to put any identifying marks on them, they were all the same Smiley
fccool59
« Reply #2 on: November 11, 2004, 10:50:12 AM »
from a quick glance under the car you can identify a high from  a low ratio by the length of the bottom bolts too.  The 2.78 and 3.08 have two longer bolts than the 3.36, 3.55 and 3.89.
griffo
« Reply #3 on: November 11, 2004, 11:05:52 PM »
Ret,
Thanks for the reply,
I had a look at the diff and it has M I 3 9 stamped on it, on the top between bolts .
Can you tell what diff it is ?
I also measured over the brake drums approx. 1435 mm.
griffo.
