August 05, 2025, 08:09:27 PM *
Author Topic: Cowl vent  (Read 1987 times)
Laszlo
« on: October 22, 2021, 10:49:24 AM »
G'day guys!
Any trick to remove the cowl vent ?
I have to do a bit of rust repair on it.
I have a feeling that will be a "fun" job....
I didn't find any topic about it.
Cheers: Laszlo
Holden = The Heartbeat of Australia
DougT
« Reply #1 on: October 22, 2021, 11:31:16 AM »
Hi Laszlo,
No real trick to it, open the vent and undo/remove the pivot screw from the vent lever (flat tip screwdriver) then unscrew the connecting rod from the vent (count the number of turns to undo, this will assist when installing). Once the connecting rod is removed, from memory, there are four mounting screws (two on each side) up under the dash securing the pivot mounts. Once undone the vent lifts out with a little bit of jiggling.  Doug
Laszlo
« Reply #2 on: October 22, 2021, 08:59:26 PM »
Thanks Doug I will try it tomorrow  !
Page created in 0.046 seconds with 16 queries.
