June 12, 2025, 11:45:02 PM *
Author Topic: FE boot hinge springs  (Read 2900 times)
texmorton
« on: July 28, 2021, 09:12:38 AM »
G'day,
On the FE I am restoring the boot springs are different on both sides, one is wider/heavier than the other. It is an early build but seems to be different to my other wreck which is has the same springs either side. Are the two different springs factory or has it been messed with? thanks Al
« Reply #1 on: July 28, 2021, 10:12:21 AM »
Tex ..The wider spring is original ..the fixed tang where the spring locates on the hinge support should be to suit wider spring on both sides ..RET on this forum sells the pivot pin repair kit , which is another problem area , indicated by having two good springs but boot lid wont stay open ,I used his kit ,it locates the spring correctly and allows for tension adjustment of the spring ..cheers Vern ..
« Reply #2 on: July 28, 2021, 11:00:47 AM »
Correction (with respect to Vern) -
The narrow spring was fitted to early FEs.  The wide spring was fitted to FC-EK.
texmorton
« Reply #3 on: July 28, 2021, 11:11:53 AM »
Right oh, thanks fellas. So it is original with one narrow and one wider spring? Al
« Reply #4 on: July 28, 2021, 12:01:26 PM »
More than likley the later wider spring was used to replace a failed narrow FE spring
« Reply #5 on: July 28, 2021, 12:46:07 PM »
OOps !!! Thanks Rob , I got it wrong , FE not FC is the model in discussion ...sorry Tex
texmorton
« Reply #6 on: July 28, 2021, 01:17:10 PM »
Great, I think that sorts it out, I will put it back together as found. thanks again fellas. Al
« Reply #7 on: July 28, 2021, 02:10:04 PM »
Tex, originally both springs would be the small ones. Check the actual boot hinges themselves, the hinge for the FE has a shorter tang which retains the spring. If you have an FE hinge with FC spring on it, it’s more likely to fall off. If you have an FC hinge then the wider FC spring will fit ok and it will locate formerly in the retainer.
Page created in 0.047 seconds with 19 queries.
