July 16, 2025, 11:07:10 AM *
Author Topic: Outer EK Wiper Arms  (Read 4215 times)
FStech
« on: May 16, 2020, 06:11:55 PM »
Hi Guys,
Couple of Wiper Arm Questions
Will EK Outer wiper arms and blades fit on my FC (straight swap)? If this is possible it will make it easier to purchase new blades.
I understand there are 2 types of EK outer Wiper Arms Vacuum and Electric, if they fit which ones do I get (and whats the difference)?
Also what wiper blades do you guys buy when fitting new blades to original FC Wiper Arms? I cant seem to find them listed anywhere.
Thank you in advance.
Steve
« Reply #1 on: May 16, 2020, 07:12:12 PM »
The only difference between FE FC and FB EK is in the way that the blade carriers attach to the outer arms. So while the components are slightly different, they are interchangeable as a set. They take the same inserts so no point in changing from that perspective.
FStech
« Reply #2 on: May 17, 2020, 05:01:38 PM »
Thanks for the reply Errol, Ill run with the latter and keep what I have grabbing some new inserts.
Steve
