August 06, 2025, 06:10:17 PM *
Author Topic: seat mounting bracket spacers  (Read 4035 times)
Roybeth
« on: May 08, 2020, 09:02:16 PM »
Hi All
I've read some posts and am still unclear as to if the seat mounting bracket spacers came with the cars originally or were they something put in later - and what they are actually for.
TIA
« Reply #1 on: May 09, 2020, 12:39:20 AM »
Originally an accessory to adjust the seat height. Became universally popular and by EK were virtually standard dealer upgrade.
Roybeth
« Reply #2 on: May 09, 2020, 07:29:09 AM »
Thanks - just wasn't sure if I needed them - though I will see once the seat is back in and I start driving her if I will need the seat raised or not.  Grin
« Reply #3 on: May 09, 2020, 07:38:07 AM »
Helen ..The seat spacers in my car were plastic and all crumbled on removal , got an aluminum set from Pete Mallaby member on this forum ,fitted quite well.he makes several items for 48 to 68 Holdens ...cheers Vern .
Maco
« Reply #4 on: May 09, 2020, 08:50:18 AM »
Pete Mallaby makes a great set of the spacers.
Better in Green
« Reply #5 on: May 09, 2020, 09:22:03 AM »
In our pano I used the fronts but left the back ones out as it gives the seat a bit of lay back
« Reply #6 on: May 09, 2020, 09:25:45 AM »
In the earlier FE's they were made from wood, which we're a little sturdier than the plastic
« Reply #7 on: May 09, 2020, 03:05:09 PM »
I used a crumbling plastic one as a template to make some from a poly??? bread board. I needed a couple of layers glued together to make up the height so stacked 8 pieces, drilled & bolted them together before cutting out to shape. It was a little time consuming but worth the effort I thought. Had they been available from Pete back them I may have opted to save myself the time. His products are very good.
Ken's 57
« Reply #8 on: May 09, 2020, 04:30:27 PM »
My FE had its original wood spacers that had split. The aluminium ones I purchased from Pete were great. Installed without any issues. Recommend!
Cheers, Ken  Smiley
« Reply #9 on: May 09, 2020, 05:55:43 PM »
Yes I have a set of black Polly ones from Pete as well. I was going to use just the front ones in my FB ute, but when I trial fitted, found that the seat would only slide back to the third last hole due to touching the parcel shelf.
