July 14, 2025, 02:14:48 PM *
Pages: 1 ... 5 6 [7] 8 9 ... 13   Go Down
Author Topic: NEW PROJECT FC UTE  (Read 101197 times)
KFV888
« Reply #120 on: August 20, 2020, 05:23:19 PM »
beautiful job on pipes... awesome build, the only thing i would change in this build is i would have fitted a 350 alloy headed TPI out of a corvette.. but nevertheless, magnificent
i for one salute you
« Reply #121 on: August 20, 2020, 07:08:38 PM »
What a test of patience! Good on you for sticking with it & producing such a result.
camxsmith
« Reply #122 on: August 20, 2020, 07:11:20 PM »
Great work, that does look like one prick of a job to do..
« Reply #123 on: August 20, 2020, 07:55:50 PM »
Yep. Very clever work. I detest the guard dump headers. Bloody tight where the steering goes through. One guy on the fb ek site managed to mix and match cast headers and get them to fit but this was a 253 and a real factory look. Your ute will be very different. Thanks for posting and keep the updates coming Malcolm. Very inspiring.
Mal W
« Reply #124 on: August 21, 2020, 05:19:05 PM »
Thanks guys, there was no way I was going to put the pipes through the inner guards as I’m no a fan of that either.
Malcolm WHITTAKER
Mal W
« Reply #125 on: August 21, 2020, 05:27:08 PM »
Picked up the new wheels today. Couldn’t be happier with the choice and fit
If the frond discs were 3 mm bigger they wouldn’t have fitted.
15 x 6 on front and 15 x 10 on the back
Malcolm WHITTAKER
« Reply #126 on: August 22, 2020, 09:29:19 AM »
Cool as Mal, please keep the photos coming as I'm really enjoying this build of yours.
Neil
camxsmith
« Reply #127 on: August 22, 2020, 05:33:50 PM »
Smokin  Love the look the rims, especially the rear with the deep dish, Nice work.
Mal W
« Reply #128 on: September 03, 2020, 06:05:55 PM »
Next I started on the fitting of the radiator. Was planning on using the original VT Commodore radiator but it just turned out to be to tall for where I wanted to fi it. So I’ve ordered one from the USA that will fit with a little less cutting up.
Same as this but complete with fans and shroud
So while I’m waiting on the radiator to turn up I started on putting some of the floor back in
Started with boxing in the front main cross member.
Then I fitted the front section of both floor pans
Next I got the transmission tunnel cut ready to fit
Currently getting the Tailshafts tunnel rolled up.
Malcolm WHITTAKER
« Reply #129 on: September 03, 2020, 11:28:48 PM »
I like your methodology malcolm👍
« Reply #130 on: September 04, 2020, 09:48:51 AM »
wish I had those skills to custom fabricate stuff ...Vern ...
Mal W
« Reply #131 on: September 13, 2020, 07:05:11 PM »
Still jumping from job to job.
Started on the sills, cut off both sills and cleaned up the inner sills
Had to do a repair on the back of the drivers sill
With the sills I’m doing the same as the FB EK utes with putting an intermediate support panel in between the inner and outer sill for extra strength
Malcolm WHITTAKER
« Reply #132 on: September 13, 2020, 07:38:40 PM »
Mal,
Not bloody bad at all.  Tell me - when putting the outer sill on, did you overhead-weld all the plug welds?  Because it looks like you can't tip the body shell over.
Mal W
« Reply #133 on: September 13, 2020, 10:46:07 PM »
Hey Rob, yes and I really hate welding upside down....
Don't know how many times I've set myself on fire.
Malcolm WHITTAKER
« Reply #134 on: September 14, 2020, 10:02:46 AM »
Hey Mal
Fantastic work as always mate, looks like the Ute was in pretty good shape even though you had to take the whole floor out; the bottom of the 'A' pillars and the inner sills all look really good.
I like the fact that you kept the seam between the 'B' pillar and the wheel arch and the outer sill, you can always tell when this area has been repaired as most just weld up and lose the seam.
I did the same with my EK Ute and made sure the seam stayed.
The 'D' bar for your steering seems pretty close to the head mate are you going to have enough clearnace for engine rock under acceleration I wonder??
As I said before great work and this is going to be a great looking Ute Mal.
Mal W
« Reply #135 on: October 04, 2020, 10:55:51 PM »
Just a quick update, have finished the both sills now.
Same as the other side, I’ve fitted an intermediate strengthening panel inside the sills
Bit of rust to repair on the rear quarter panel also
Just have to put a new panel into the lower rear quarter panel to sill area.
Next ive cut and trial fitted the trans tunnel and tailshaft tunnel
Not going to weld it in yet until I get the shifter and handbrake as they both fit onto the gearbox and they will be easier to fit to start with, without the trans tunnel in.
Tomorrow I’ll start on cutting in the floor pans.
Malcolm WHITTAKER
Mal W
« Reply #136 on: October 20, 2020, 09:50:15 PM »
Ended up making new engine mounts, the standard ones were just way to much messing around to change
Malcolm WHITTAKER
Mal W
« Reply #137 on: October 20, 2020, 10:20:47 PM »
My version of tough mounts
Malcolm WHITTAKER
ehefiv8
« Reply #138 on: October 21, 2020, 12:34:08 PM »
Hi, excellent work on your project. The radiator you have ordered, is that a standard size they sell?. Do you have a part number?. Thanks Scott
« Reply #139 on: October 21, 2020, 08:50:01 PM »
Thanks for the update Malcolm. Magnificent work!
Clay
Pages: 1 ... 5 6 [7] 8 9 ... 13   Go Up
Page created in 0.049 seconds with 19 queries.
