April 04, 2025, 10:11:22 PM *
Pages: 1 ... 7 8 [9] 10 11 ... 13   Go Down
Author Topic: NEW PROJECT FC UTE  (Read 98045 times)
Mal W
« Reply #160 on: February 08, 2021, 05:51:19 PM »
Bonnet repairs
The inside of the bonnet had a fair bit of surface rust and a couple of holes on the front so I removed the front and rear inner bracing and acid cleaned the bonnet skin inside and out and sandblasted the 2 bracing sections.
The bonnet has now been sent away to get louvred
Malcolm WHITTAKER
Mal W
« Reply #161 on: February 08, 2021, 05:57:44 PM »
Next the alternator
I ended up getting a new 140 amp alternator and wanted to do a low mount bracket with the Gilmer belt set up.
I couldn’t but one that was just going to be a bolt on so I had to make it myself. The low mount didn’t give me much room to play with either
Was sweeting bullets with the length of the belt, but it ended up fitting perfectly with plenty of adjustment
Malcolm WHITTAKER
Mal W
« Reply #162 on: February 08, 2021, 06:11:52 PM »
I finally got the tyres fitted to the rims so I could cut the diff to length and get that area all finished off.
I ended up using 265/50/15 on the back and 185/65/15 on the front.
The rear tyres are a nice snug fit.
The front tyres I’m hoping will be ok for clearance to the guards
Malcolm WHITTAKER
Mal W
« Reply #163 on: March 29, 2021, 11:06:39 PM »
Bit of an update
Modified the wall behind the seat to move it back 50mm
Malcolm WHITTAKER
« Reply #164 on: March 29, 2021, 11:28:52 PM »
Wow. A lot of work. I’m glad I’m only 6ft nothing. Got my seat back against the rear wall in my ute and there are two holes left on the runners.
Mal W
« Reply #165 on: March 29, 2021, 11:31:06 PM »
Now started on rebuilding the rear tray floor
Firstly starting with the wheel arches, making them 50mm wider
Now for the next side
Malcolm WHITTAKER
purrlx
« Reply #166 on: March 30, 2021, 05:00:14 AM »
Looks good, well done
FireKraka
« Reply #167 on: March 30, 2021, 10:47:43 AM »
Was wondering where you got to Mal  Grin
Love the work you are doing on this Ute it is going to turn out spectacular mate.
Neil
Mal W
« Reply #168 on: March 31, 2021, 07:03:59 AM »
Yesterday I got a bit more done on the LH rear wheel arch up to where I decided to do a bit of fuel filler surgery while that area was still accessible.
Been struggling with the fuel filler option in my head for a while and bought a flush mount filler door that I was going to put in place of the original recessed one.
This change came about as I was going to have to change the routing of the filler tube, due to the inlet on the Mustang tank being in the middle at the back
So ended up not using the new filler door at all and cut out the original recessed one and filled it in all together
The old one cut out, and new piece marked out ready to trim and fit
Nothing like welding on a big flat area and then spending the next couple of hours slapping it up to get the wobbles out of it
Malcolm WHITTAKER
Soulman
« Reply #169 on: April 04, 2021, 09:51:13 AM »
Hi Mal
 Fantastic work throughout. look forward to see finished results.
Who have you used for engineering?
I have a ute also. I've just picked up a VY with V6.
And so the journey begins.
Cheers Ross
Mal W
« Reply #170 on: April 04, 2021, 11:31:38 PM »
Ross
All Vehicle Certification Services did my ute.
Randal HASWELL a great bloke to deal with.
https://au.linkedin.com/in/randall-haswell-a5087651
Malcolm WHITTAKER
Mal W
« Reply #171 on: April 15, 2021, 07:49:35 PM »
Finally finished off my fuel filler relocation. Decided to put it in the back.
Just a bit of press work and shaping to start with
Then to fit it
A bit of messing around remaking the new filler tube into the top of the tank
Now for the cover up
And pretty happy with how it all turned out
Malcolm WHITTAKER
« Reply #172 on: April 15, 2021, 07:57:11 PM »
Works well with the mustang tank
FireKraka
« Reply #173 on: April 16, 2021, 08:44:46 AM »
Nicely done Mal
Mal W
« Reply #174 on: May 01, 2021, 08:27:48 PM »
Rear door made for access to the battery, electric power steering, electric air con compressor and air con evaporator. The door has gas rams to keep it open and closed. Works great.
Now just have to sheet it all off .
Malcolm WHITTAKER
Mal W
« Reply #175 on: May 01, 2021, 08:36:27 PM »
Just catching up on the updates
She’s finally back on the rotisserie with just a few welds to finish off and then it’s off to the sand blasters
Quite overwhelming when I sit back and look how far it come
Malcolm WHITTAKER
« Reply #176 on: May 01, 2021, 09:00:37 PM »
You’re not wrong Malcolm. Amazing work.
« Reply #177 on: May 03, 2021, 10:50:41 PM »
Love it!
Thanks for all the updates.
Mal W
« Reply #178 on: May 16, 2021, 07:45:48 PM »
While waiting on the sand blaster I did a bit more work in the tray.
I finished of the lid
I used the same profile in the lid as the inside tailgate
Malcolm WHITTAKER
Mal W
« Reply #179 on: May 24, 2021, 07:44:19 PM »
Picked up my bonnet and sun visor after getting the vents cut in.
Love the look, they did a great job
Malcolm WHITTAKER
Pages: 1 ... 7 8 [9] 10 11 ... 13   Go Up
Page created in 0.051 seconds with 19 queries.
