August 27, 2025, 04:39:20 AM *
Pages: 1 ... 6 7 [8] 9 10 ... 13   Go Down
Author Topic: NEW PROJECT FC UTE  (Read 117446 times)
Mal W
« Reply #140 on: October 23, 2020, 04:35:21 PM »
Scott the radiator is a standard size. Part number GRI-CU-56271-xs
Mal
Malcolm WHITTAKER
Mal W
« Reply #141 on: October 24, 2020, 09:28:36 AM »
My gear shifter and handbrake finall turned up. Si I fitted those up, very happy with my choice
Next was trial fitting up the brake booster and master cylinder, and of corse nothing is straight forward
The bolts on the booster were way to far apart for the master cylinder to just bolt straight on
So I had to knock up an adapter plate to suit
Pretty easy job
Only had to cut a small piece from the return part under the dash to get the 8 inch booster fo fit
I’m planning on mounting the reservoirs under the ash tray lid in top of the dash. That’s today’s job.
Mal
Malcolm WHITTAKER
Mal W
« Reply #142 on: October 24, 2020, 10:25:23 AM »
Update also on the floor pans
Transmission tunnel welded together
Then started making the floor pans
Also added some gussets into kick up on the rear rails
Both sides cut to fit
Malcolm WHITTAKER
ehefiv8
« Reply #143 on: October 24, 2020, 11:51:49 AM »
Mal
Thank you Mal
my8thholden
« Reply #144 on: October 24, 2020, 05:40:06 PM »
just awesome Mal , no doubt about you , and the other guys on here into serious resto's ..loving following ...Vern ..
Mal W
« Reply #145 on: November 25, 2020, 12:31:33 PM »
Just started making the exhaust system
This is going to be a long tedious job
Some of the bits I started with
Lots of grinding involved
Both front pipe sections done
Now to go into the x pipe
Malcolm WHITTAKER
Mal W
« Reply #146 on: November 25, 2020, 12:32:53 PM »
Malcolm WHITTAKER
my8thholden
« Reply #147 on: November 25, 2020, 09:53:45 PM »
awesome ,just awesome ,class all the way ,it looked like electro polished before welding and after ,how did you do that ?
Mal W
« Reply #148 on: November 26, 2020, 07:48:27 AM »
The system is going to be full 2 1/2 inch stainless
Its all stainless steel and most parts are polished when I buy them.
I use stainless wire in the mig to weld everything together
The most tedious part is the grinding, being careful to only grind the weld.
When I have the weld ground close, I use a flap wheel in the grinder, then 120 sanding disc, then 320 sanding disc, then polish the section on the pedestal polisher.
Malcolm WHITTAKER
old-blu
« Reply #149 on: November 26, 2020, 08:52:03 AM »
 This is an amazing project to witness as it progresses. Worthy of a TV Doco. It more than compares to the  American Custom shows. The standout for me is that it is a "one man band" & not a workshop Team effort.  Will this get to the HILL in 2022? Top stuff Mal.   Cheers Kevin.
6th, may 1958 "I was there".
my8thholden
« Reply #150 on: November 26, 2020, 02:21:58 PM »
That polishing would take 10 times at least the welding time ,do you use a buffing bar like Josco on the fabric buffing wheel ?
Mal W
« Reply #151 on: November 26, 2020, 09:24:40 PM »
Yep thats exactly what I use
Malcolm WHITTAKER
Mal W
« Reply #152 on: November 29, 2020, 11:04:38 PM »
Only had a few hours in the shed today as it was so hot I started to melt, so not a lot done
Malcolm WHITTAKER
Mal W
« Reply #153 on: February 07, 2021, 08:00:10 PM »
Exhaust all finished
Malcolm WHITTAKER
my8thholden
« Reply #154 on: February 07, 2021, 09:47:39 PM »
you have had a brake in your postings ,I can see why ,that is awesome ,Vern
Mal W
« Reply #155 on: February 07, 2021, 10:04:51 PM »
Yeh its been a while Vern, have got lots of updates to come.
Malcolm WHITTAKER
FireKraka
« Reply #156 on: February 08, 2021, 11:19:11 AM »
Good to see you back Mal was wondering what had happened please keep the updates coming.
Neil
Mal W
« Reply #157 on: February 08, 2021, 05:34:06 PM »
Next, radiator all fitted up
Radiator is a Griffin that I got from the States
Made up saddles for it to sit in and these are welded on with the top being held by made up brackets that are welded to the top radiator support brace
Not a lot of room in there
Malcolm WHITTAKER
Mal W
« Reply #158 on: February 08, 2021, 05:43:06 PM »
Moving on to the top cover panel and modified bonnet catch
I made up a section to go around the radiator cap and welded it into place
The next problem was the radiator cap hitting the inside of the bonnet support
Nothing a bit of cutting couldn’t fix
Malcolm WHITTAKER
Mal W
« Reply #159 on: February 08, 2021, 05:46:12 PM »
Bonnet catch modification
I didn’t like the look of the cable so a bit of welding and messing around and now the cable is out of sight
Malcolm WHITTAKER
Pages: 1 ... 6 7 [8] 9 10 ... 13   Go Up
Page created in 0.04 seconds with 15 queries.
