April 04, 2025, 03:43:06 AM *
Pages: 1 ... 8 9 [10] 11 12 13   Go Down
Author Topic: NEW PROJECT FC UTE  (Read 97976 times)
Mal W
« Reply #180 on: May 24, 2021, 09:13:51 PM »
+2
Finally got the ute to the sandblasters, a couple of hours later and it’s all done, then home to get primed.
She’s starting to go ahead in leaps and bounds now.
Malcolm WHITTAKER
blacky
« Reply #181 on: February 10, 2022, 07:45:03 PM »
any updates Mal Huh?
Billy Blackarrow
« Reply #182 on: February 10, 2022, 09:09:24 PM »
 I was wondering how he is going as well BLACKY It has been a while since his last update hope he is doing better than me
BILLY BLACKARROW
« Reply #183 on: February 11, 2022, 11:23:58 AM »
There are some updates on Facebook - https://www.facebook.com/groups/862124657272742/user/100000074020024/
Mal W
« Reply #184 on: February 11, 2022, 02:55:29 PM »
Sorry guys, can’t keep up with the updates and have been posting on the modified FE FC Facebook page
Malcolm WHITTAKER
ipg
« Reply #185 on: February 11, 2022, 03:03:08 PM »
we thought you'd been banned from the forum  Roll Eyes
Mal W
« Reply #186 on: February 11, 2022, 11:55:11 PM »
Hey all, been a fair bit done to date.
All the floor is finished.
The air con, battery tray and power steering pump is in the hatch area behind the seat wall
The lift up floor in the back is done.
I made quick release hinges for the lift up floor lid
The strips I made for the back I had chromed
I made polished stainless rods to hold the tailgate to replace the old rusty ones.
Each side was made up of 5 pieces all welded together and then polished.
I’ve repaired the tailgate inside and out and the tail light panel
I also made up these little trims to go on top of the tail lights. These were ground down from sedan trims.
I made and fitted hidden tail gate hinges
I’ve made a hard cover for the back that’s operated by electric rams.
The hinges took a fair bit of working out but I ended up using VN Commodore bonnet hinges
Instead of using gas rams on the lid I used linear actuators
Then I designed and made quick release top actuator brackets in case the electrics failed. These were operated by a cable similar to the bonnet release cable. When you pull the cable the top bracket drops down and allows you to lift the lid by hand.
The top will be covered with water proof vynal.
Malcolm WHITTAKER
my8thholden
« Reply #187 on: February 12, 2022, 08:15:45 AM »
Brilliant Mal , just brilliant..Vern
« Reply #188 on: February 12, 2022, 10:33:13 AM »
Your design and engineering work is brilliant.  Absolutely stunning
« Reply #189 on: February 12, 2022, 06:14:18 PM »
Thanks Malcolm for going to the trouble of posting it on here. Looking on Facebook isn’t the same. Custom work with the tailgate and hard lid is brilliant. The rest of your work is simply outstanding of course. Inspiring stuff.
ekute
« Reply #190 on: February 12, 2022, 08:10:27 PM »
Great engineering Mal keep posting. Love your work
FireKraka
« Reply #191 on: February 12, 2022, 09:25:55 PM »
All I can say is WOW absolutely amazing work.
Mal W
« Reply #192 on: February 13, 2022, 12:05:21 AM »
Thanks guys for the supportive comments.
Another little bit I made was a stainless trim to go around the number plate recess.
This I made out of 2 EJ Holden cowl-panel moulds.
The 2 trims were cut into 3 pieces and welded together with stainless wire in the mig.
Malcolm WHITTAKER
Mal W
« Reply #193 on: February 14, 2022, 05:39:45 PM »
Just finished off the release cable for the hard cover.
Malcolm WHITTAKER
« Reply #194 on: February 14, 2022, 08:51:30 PM »
Great work Malcolm. Free room and board at my place any time you are in Willunga mate!
Mal W
« Reply #195 on: February 14, 2022, 09:41:31 PM »
Thanks mate, I’m planning on putting some K’s on the old Ute when she’s done.
Malcolm WHITTAKER
« Reply #196 on: February 14, 2022, 11:05:40 PM »
Shameless plug for the FB EK nats at Nuriootpa June long weekend
Mal W
« Reply #197 on: February 15, 2022, 03:33:01 PM »
Got my new gauges for the Ute.
They look great. Came from Classic Instruments in the states.
That will be my next job I think doing the mods to the dash to fit the instruments
I had the made with the red needles.
Malcolm WHITTAKER
Mal W
« Reply #198 on: March 02, 2022, 06:04:57 PM »
Finally finished off the new dash, started with separating the inner and outer sections
Then fitted the new speedo, this just needed a bit of trimming to make the hole about 3mm bigger all round
Then made the new section for the other gauges and warning lights
Then welded them in
Next was to modify the plastic facia. I wanted to keep with the original look.
The facia was cut into 5 pieces to start with.
I sanded all the inside and outside of the plastic and taped it in place to the dash where it had to go. I then joined it all together with normal body filler. I also filled in the back for a bit more strength.
Once the facia was finished I did a bit of tidy up on the dash panel
Starting to take shape
Then for a bit of primer, I also sprayed a bit of black on the facia to show how it will look all finished
Thanks for looking
Malcolm WHITTAKER
« Reply #199 on: March 02, 2022, 09:27:04 PM »
I'll take one!
This looks great Mal, a lot of thought and work there has paid off
Pages: 1 ... 8 9 [10] 11 12 13   Go Up
Page created in 0.051 seconds with 17 queries.
