August 21, 2025, 12:45:00 PM *
Author Topic: Newbie here my fc  (Read 21021 times)
The holden man
« on: April 22, 2019, 11:20:34 AM »
Hi guys, names adam,new member to the forum but have looked up info here in the past, have been playing around with old holdens (mostly fe-fc and hk-t-g)since i was a teenager (37  now) i work for an engine builder in the albury/wodonga area and have a soft spot for hot greys will post some photos up of my toys, i have a 59-1/2 fc special which is going for its second rwc test tomorrow, and we managed to squeeze 130rwhp out of the old fc L block, it is pretty cranky and piggy to drive but wouldnt have it any other  way
Also have an fe panel van that was my paddock basher as a kid, just lucky i never wrecked it, its fitted with a 383 sbc and commodore 6spd but still going through th conversion process
The holden man
« Reply #1 on: April 22, 2019, 11:53:43 AM »
Myfc https://imgur.com/gallery/Kkc49p4
« Last Edit: July 14, 2019, 05:15:26 PM by RET » Logged
The holden man
« Reply #2 on: April 22, 2019, 12:07:20 PM »
Myfc https://imgur.com/gallery/CXgbSiu
« Last Edit: July 14, 2019, 05:16:03 PM by RET » Logged
The holden man
« Reply #3 on: April 22, 2019, 12:08:49 PM »
Myfc3 https://imgur.com/gallery/oFDXsYs
« Last Edit: July 14, 2019, 05:16:37 PM by RET » Logged
The holden man
« Reply #4 on: April 22, 2019, 12:12:05 PM »
Myfc https://imgur.com/gallery/aTaw5yO
130rwhp 132ci https://imgur.com/gallery/FLjmCDe
« Last Edit: July 14, 2019, 05:17:48 PM by RET » Logged
JOX515
« Reply #5 on: April 22, 2019, 12:31:01 PM »
Looks good mate Smiley
The holden man
« Reply #6 on: April 22, 2019, 12:38:36 PM »
Thanks, here's the before pic
https://i.imgur.com/iszRBUr.jpg
camxsmith
« Reply #7 on: April 22, 2019, 03:53:51 PM »
Looks great well done ..  hope you don’t mind a re posted a couple of images.. Grin
The holden man
« Reply #8 on: April 23, 2019, 08:54:05 AM »
All good, thanks for doing that, took me a bit to get that imgur app worked out Grin
« Reply #9 on: April 23, 2019, 09:24:37 AM »
Very nice and stock looking. I bet a different impression comes across when you turn the key.
The holden man
« Reply #10 on: April 23, 2019, 09:38:28 AM »
Sure does, with a 2-1/2" exhaust and pretty big cam, a crow regrind, marty put a humpy holden speedway gring on it,
Its actually an old repco sports engine +.060 so .185" oversize from standard fc block, still running the repco pistons,
We took .030 of the block to zero deck it then about .080" off the head i ported out to get the comp upto 9.5:1,
186 valves
Double race springs to suit a series 1 v6 commodore
The holden man
« Reply #11 on: April 23, 2019, 09:42:37 AM »
Had to make up custom pushrods to suit using 265 hemi pushrods with the grey pushrod tip machined down and inserted then silver soldered, slant 6 full flow oil fiter setup drilled and tapped into the block, made 130rwhp at about 6000rpm but was starting to pull vaccum so triples should see more power
2brite
Cruizin's devine in a '59
« Reply #12 on: April 23, 2019, 08:26:13 PM »
a video with the grey on song would be nice to see.
go the mighty grey
« Reply #13 on: April 23, 2019, 08:30:59 PM »
So effectively a 138 plus 60 thou, for 149cui. Hi comp. Good breathing. Not so powerful to stress bottom end and drive train. Bit of an adventure to drive. Sounds like a good way to go. You’re not lazy like me and put in a red motor.
Clay
The holden man
« Reply #14 on: April 23, 2019, 09:23:53 PM »
Next time i put it on the dyno at work i'll get a vid, and yeah worked out to 149ci with the 3.185"-3-3/16 bore, took about 7kg out of the flywheel to, would be heaps better with a four speed but i kind of like the column shift nostalgia, my fe van on the other hand should be a weapon with the alloy headed 383, tr6060 6spd and torana front end
« Reply #15 on: April 24, 2019, 12:11:23 PM »
Yes yhe old nostalgia box should stand up to it if you don’t hammer it. You only need syncro in city driving. So I keep telling myself as I don’t want to cut the floor in mine.
The holden man
« Reply #16 on: May 08, 2019, 08:38:54 PM »
https://i.imgur.com/yqbaZdv.gifv
Hi guys, hopefully this works, was the first dyno run of the fc from a couple months ago before we tweeked the timing and carbs a lil further, only revving to 6000rpm should be good to 7000rpm but going to wait till it loosens up a bit to rev it that hard
« Reply #17 on: May 09, 2019, 12:20:58 AM »
Oh boy! Oh boy! Oh boy! Oh boy!
2brite
« Reply #18 on: July 14, 2019, 12:59:19 PM »
awesome looking sedan
any engine bay pics
The holden man
« Reply #19 on: July 14, 2019, 07:55:22 PM »
Thanks, there is one pic above, i'll try and get onto taking some more pics during the week, have got some of the buildup process pics i'll put up as well, these days im pretty pushed for spare time and need to sit down for a while to juggle the pics to imgur then onto here
