June 15, 2025, 11:44:53 AM *
Author Topic: wheel rims  (Read 5052 times)
« on: April 19, 2019, 06:49:45 AM »
Gents..I need two (2) 13'' x 5 stud wheel rims ,obviously in good condition ,to match the three I already have ..stamped inside the rim is ... 13'' X 4.5J 4/64 HOLDEN 42 ,a quick way to tell the strengthing pressings between the stud holes are triangular in shape not a raised dome ,I have a rim stamped 13'' x 4.5JJ 7/73 6S HOLDEN and a circular ring with A over T in it and word Australia in horse shoe shape ,which I would swap/sell for one, they look the same ,but offset is different .I need to replace that one for a set of 4 and a spare.I cant be fussy about the year ,as long as its the same type..Thanks in anticipation Vern..
I can send and receive images on my mobile ,I cant post here ..0405 703 413 ..
Corey05
« Reply #1 on: April 19, 2019, 08:08:38 AM »
Hi Vern,
I have taken some photos and will send have four rims with tyres on them so I can't check the stamping but have the triangular stamping.
Corey
« Reply #2 on: April 19, 2019, 09:46:22 AM »
Vern,
Three of your rims are from an EH (that's why the 4/64) and the fourth is from an LJ Torana (hence 7/73).
One not-often-appreciated thing is that Torana and HT-G rims damage standard brake drums.  The original brake drums have slightly raised sections between the stud holes (the triangular pressings in the original wheel rims clear them).  But Torana rims bear down on the hub around the full circle, and when you tighten the wheel nuts down, the rim deforms the drum.
« Reply #3 on: April 20, 2019, 07:50:40 AM »
Hi Rob and Corey ..That is very interesting about the LJ Torana rim  .I did not know about the effect it has on the FC brake drum ,I just noticed the pressing differences and offset difference ,so thanks for the advice on a potential problem ..So any one out there need a LJ Torana rim?Huh I am in discussions with Corey on rims he has ..thanks Vern ..
« Reply #4 on: April 21, 2019, 07:15:37 AM »
Morning all ..Whilst getting a circlip from local tractor repair guy to retain the cable in end of handbrake shaft under dash ,I scored one rim ,a real chance find he just happened to have,so I need one more ,pref  Sydney or out to central west NSW where I go ..happy to swap the 1973 13'' Torana rim I don't want to use ..Vern
ekute
« Reply #5 on: April 23, 2019, 08:39:32 PM »
Hi mate I have one you can have and I can drop it off in Petersham on Saturday.
« Reply #6 on: April 23, 2019, 08:54:35 PM »
Good luck on your hunt Vern. I’ve got rims but hey I’m in SA doh!
Clay
« Reply #7 on: April 23, 2019, 09:43:06 PM »
Hi Mark ..Well that would be great ,you have a rim ,let me know where to collect it ,I have a mate in the city ,I am sure he can collect for me ,give me a number so he can call the third party to make a mutual time ,what consideration do you want from me ?  Vern..
you can PM me or ,,0405 703 413 .. Vern
« Reply #8 on: May 01, 2019, 06:54:16 AM »
Mark ..I have the rim ,thanks to your daughter and my daughter ,and your good self..Its great,thank you ,I now have 5 matching original Holden rims so, off to glass / garnet /sand/ walnut/ dustless / eco green/what ever blasters ..Vern
« Reply #9 on: May 01, 2019, 07:09:21 AM »
gents in thanking Mark I forgot ,Corey ,Clay,Ken and Rob with their offers ,so thanks all round,the beauty of this forum ..Vern
Corey05
« Reply #10 on: May 01, 2019, 11:21:41 AM »
no problem great to see you got there in the end.
cheers Corey
« Reply #11 on: May 01, 2019, 07:55:12 PM »
Good work Vern 👍
