August 20, 2025, 10:20:46 AM *
Author Topic: fc ute sill replacement  (Read 2640 times)
Gary C
« on: January 18, 2019, 07:05:31 PM »
I have replaced outer sills on my fc and fe sedans and now looking replacing both outer sills on me fc ute.
Thing is can you access from B pillar back to wheel arch from cutting old sill out from outside or do you need to turn yourself into a chimpanzee and access this section  from inside ute?
« Reply #1 on: January 18, 2019, 11:41:22 PM »
Hi Gary
You can cut off the old outer below the seam and drill out the spot welds from underneath, or grind and peel off. The hard part is re-joining the new sill. This has to be done from inside. It is made easier when the floor is out. The floor went in last in the factory I believe.
Clay
Gary C
« Reply #2 on: January 19, 2019, 09:50:38 AM »
Thanks Clay I will give it a shot
philwreck
sa-club
Online Online
« Reply #3 on: January 19, 2019, 10:48:32 AM »
HI Gary
you might look at using panel glue just for that small section , have used it with good results.
  phil.
Page created in 0.062 seconds with 17 queries.
