May 23, 2025, 03:10:52 AM *
Author Topic: V6 conersion  (Read 5196 times)
freddyc
« on: February 25, 2017, 08:30:55 AM »
got my VR V6 motor to run yesterday but when we plugged the snapon scan tool up it did not register or pick up the motor. Has any one got any ideas??
fred
Townsville North Queensland
« Reply #1 on: February 25, 2017, 12:30:47 PM »
Is it a conversion harness? What wiring did you end up with?
Most snap on readers are OBD2. VR V6 is ALDL (or crudely sometimes called OBD1). Your reader won't pick it up.
BUT if you have a warning light you can bridge pins 5&6 to get the warning light to flash in a series of blinks to give error code numbers
freddyc
« Reply #2 on: February 25, 2017, 05:19:38 PM »
I ended up using the harness that came in the kit with the body control module. I am not to good at this techno stuff.
fred
FireKraka
« Reply #3 on: February 26, 2017, 09:50:43 AM »
Hi mate I would have said exactly what NES did best way is to bridge the terminals as stated on the diagnostic plug if you have a commodore manual it will give you a list of the codes and you want it to flash 12 that means everything is ok
Neil H
« Reply #4 on: February 26, 2017, 12:43:08 PM »
Please post photo and model of the scan tool your using. I reckon it's and OBD2 which won't work
freddyc
« Reply #5 on: February 28, 2017, 07:59:22 AM »
not sure which scan tool my mechanic is using. Being a mechanic I hope he knows what he is doing. I have a transmission leak atm so wont fire up again until this is fixed.
fred
« Reply #6 on: February 28, 2017, 03:16:11 PM »
Well I'd hope he knows. Otherwise it'll be a loose wire on the port which is unlikely?
You could buy a cheap ALDL scanner and see if it works when on accessories...
FireKraka
« Reply #7 on: February 28, 2017, 05:33:14 PM »
Hi Fred post a photo of the port the mechanic is plugging into please.
Neil H
freddyc
« Reply #8 on: February 28, 2017, 09:33:30 PM »
I don't know how to post photo's on here.
fred
FireKraka
« Reply #9 on: March 01, 2017, 01:16:54 PM »
Mate I use TinyPic upload the photo from my computer to TinyPic the copy the URL for forums and paste it in the post you are trying to do.
Hope it helps.
Neil H
