Offline
« Reply #60 on: April 03, 2016, 09:21:40 PM » |
Is the axle for the LC LJ rear ......Fc427......
« Reply #61 on: April 04, 2016, 05:48:25 AM » |
Yep 1 has a twist in it and looks ready to shear the splines off.
Offline
« Reply #62 on: April 04, 2016, 10:00:22 PM » |
Will take a look for you in the next few days ...Mark
« Reply #63 on: April 05, 2016, 07:07:36 AM » |
Pete, there is a pair of custom axles on eBay at the moment. Not sure of the price or if they will suit you. Jim
« Reply #64 on: April 05, 2016, 07:09:21 AM » |
Thanks Jim
But the studs will be too big to get my wheel studs in..
I will find 1..
« Reply #65 on: April 05, 2016, 06:19:11 PM » |
Doesn't VPW carry ones you can trim down?
« Reply #66 on: April 05, 2016, 08:32:09 PM » |
But they have drilled the flange out to suit bigger diameter studs/nuts mine only just fit now if u get me so mine use a 19mm socket they will be 21mm wont get that in there
« Reply #67 on: April 05, 2016, 10:11:25 PM » |
Ahh yep that's a problem.
Offline
« Reply #68 on: April 06, 2016, 08:08:23 AM » |
Pete I only have a complete diff but ebay Item: 261408558922 might be ok Mark
« Reply #69 on: April 06, 2016, 11:02:32 AM » |
Pete; Blacky on the FB EK forum tells me that you can get wheel studs that have a larger diameter spline area for pushing into the flange but maintaining the original thread diameter?    ?? I don't know where you can get them but he said that he has used them. May solve the issue with the VPW axles Regards Neil H
philwreck
sa-club
Online
« Reply #70 on: April 06, 2016, 12:32:28 PM » |
Hi pete, do have an axle here (in gawler s.a.) you would be welcome to it ,but freight is the question.if you cant source one there locally we will have to work it out...phil.
camxsmith
« Reply #71 on: April 06, 2016, 02:19:20 PM » |
Hi Pete Have a look at this listing I see there is a LC axle in the pile of bits might be worth looking into. ebay
« Reply #72 on: May 03, 2016, 06:52:56 AM » |
Finished the wagon last night . So things I have found doing a LJ torana diff conversion. LJ axles are left and rh sided ? only a few mm in it but enough to upset the planetry gears I thought they were universal. Handbrake cable was another one. I went to chop the ends off a HR cable and adapt to the FC cable then I did a ebay search and they make them to suit the conversion for $120 so that fixed that. I knocked out the studs on the housing and gave the face a quick hit with a ceramic combi click disc as it had some rather large lumps from having a heap of centres over tightened. I put new copper washers onto the studs with some sealer before pulling the studs back in. If using nolethane spring insulators they are wider to suit EH hr style springs so need a groove die ground into it so the u bolts can slip past them. I am having a custom made rear hose made today but a HR one should work fine. The tyres tuck in really nice now only around 15mm inside clerance either side. If they rub i will go longer studs with spacers to get them sitting perfect.
camxsmith
« Reply #73 on: May 03, 2016, 07:07:08 PM » |
Nice work Pete... so that what I need to get mine to look like
« Reply #74 on: May 04, 2016, 10:28:21 AM » |
Great job Pete. You set the bar higher & higher.
Dave 0417 270 315
« Reply #75 on: May 05, 2016, 06:26:25 PM » |
Well i took the wagon for a run and it rubbed. So i found that trailer studs at the local parts shop are perfect about 15mm longer i did have to redrill the flanges to 14mm then i made a brass spacer with a chamfer so when i rattle the studs in they pulled straight. perfect nice and tight then i cut 2 6mm spacers on the water jet in aluminium there is still a bit of axle sticking thru the alloy spacer.
Took it for a run beutiful quiet as very happy..
now to wire up the brake controller and trailer plug.
camxsmith
« Reply #76 on: May 05, 2016, 08:27:18 PM » |
Hey Pete have you got a picture of it on the ground.
« Reply #77 on: May 05, 2016, 09:04:28 PM » |
ill take one tommorow with the van on i had 30mm taken out of the springs it should of sat 10mm lower than where it was and its got rake which i hate so if it doesnt settle im pulling it apart and getting 50mm more taken out ..
« Reply #78 on: May 05, 2016, 11:29:20 PM » |
That's it Pete. Fk with it till it's the way you want it
« Reply #79 on: May 08, 2016, 06:56:59 AM » |
All finished. Took friday off to fit new towbar and tongue which i made and had powdercoated. (Half original towbar half new) Wire in new trailer plug with braided line and sealed gland nut. Wire in redarc brake controller. Rip dash cluster out and re wire the birds nest so it actually looks half tidy. After towing the van to its first show i was pleased i only heard to tyre touch once when i hit a large bump and took out top display. Only 1 dampener for the day a lady tried ripping the door off the van saying it doesnt even open i said its locked to keep people like you out.     Sent from my SM-G920I using Tapatalk
