August 28, 2025, 02:28:01 AM *
Pages: 1 ... 15 16 [17] 18 19   Go Down
Author Topic: Cams FC Resto  (Read 215179 times)
camxsmith
« Reply #320 on: October 22, 2020, 10:29:04 AM »
Just some more cleaning up
camxsmith
« Reply #321 on: October 22, 2020, 10:30:26 AM »
Good to see your still motivated Cam ..
Thanks Pete.. I sort of love doing it this work .. just finding time is always the hardest thing. as you know too well  Grin
camxsmith
« Reply #322 on: November 18, 2020, 04:51:40 PM »
Time to get the other rocker panel on
Cleaned up and test fit and was happy of the first trial fitting
While the bottom of the B pillar was open good time to get in the seat belt mounting plates. The top plate can be installed from the bottom of the B pillar (when rocker panel is removed) , but this is easiest done when the car is on the rotisserie as the plate needs to slide along the out side edge of the B pillar as it goes past the door hing mounting plates. If that Makes sense.
  (sorry for the shit pic was late)
Got the rear drums sorted, Machined and painted.
One of the rear springs was pulled apart
Finally got a nice day with out wind or rain to paint some items, The internals of the rocker panel, rear leaf springs, stabilizer bolts, rear spring plates, front end lower arms and front end caps
Longman
« Reply #323 on: November 18, 2020, 09:14:51 PM »
Strewth, you've been busy Cam. Nice work
« Reply #324 on: November 19, 2020, 07:24:57 AM »
Good Job mate well done
camxsmith
« Reply #325 on: December 01, 2020, 04:27:58 PM »
Sills are on ..  just got to clean up the b and c pillar joins
One spring put back together with new center bolts and rubber guides, old ones were shot
Other rear spring pulled apart ready to be treated
Longman
« Reply #326 on: December 01, 2020, 06:00:25 PM »
Man, you're a busy beaver Cam!
camxsmith
« Reply #327 on: December 06, 2020, 09:36:59 PM »
Finished of the bottom of the A pillar, now on to the B.
JOX515
« Reply #328 on: December 06, 2020, 09:41:34 PM »
Looking really good Cam, you must be seeing light at the end of the tunnel soon... Smiley
camxsmith
« Reply #329 on: December 07, 2020, 07:51:48 PM »
OK B pillar done now for the C .
camxsmith
« Reply #330 on: December 07, 2020, 07:57:19 PM »
Hi Graeme  Bloody covid came... I have been wanting to come over for so long and go for a spin with ya in your car.   Will have to do it soon ..  Maybe next week if your around, this week is to crazy for me at the moment.
Light at the end of the tunnel ..  I feel its a very small light at the moment, but this metal work is a very huge part of putting the car back on the ground. And I'm trying my hardest not to rush it and do it right.
Just want to drive it really   Tongue
« Reply #331 on: December 08, 2020, 06:41:59 AM »
gees mate . from A pillar finished to B pillar finished in 2 days ,don't think a robot can do that ,and your takin it easy to get it right , Cam The Flash , no wait Flashcam or Dashcam ...Vern
JOX515
« Reply #332 on: December 08, 2020, 09:27:00 AM »
Cam, you can come and take my car cruising anytime you like mate as I am not using it all that often....
camxsmith
« Reply #333 on: January 03, 2021, 10:17:31 PM »
Been looking at that C pillar long enough now, thought i better start. not a lot left once you cut out the shit bits.
Started with the top bit
Then the inside
Then I called it a day. I do have the outside piece cut out and marked.  (no photo)
« Reply #334 on: January 04, 2021, 10:26:47 AM »
Well done Cam, once you have it all done you will be able to look back with a real sense of achievement
All the best for the new year
camxsmith
« Reply #335 on: January 21, 2021, 08:43:16 AM »
Now for the outer piece
Put in place after a lot of tapping with the hammer on the old anvil
welded in and polished up
Just need to clean up and reattach the door rubber channel you can see hanging off there
Rod
« Reply #336 on: January 22, 2021, 03:32:33 PM »
Gee Cam, you are making good progress now. Those rust repairs must nearly be done.
Cheers Rod
camxsmith
« Reply #337 on: January 24, 2021, 09:29:58 AM »
I wish that was the case Rod,  but it seems I have a terrible nack of finding  rust.. Shocked  Cheesy
Another hole fixed.
Now to close up the sill under the guard
camxsmith
« Reply #338 on: January 29, 2021, 02:11:32 PM »
Pieces are made to close of end of sill
But before I do I want to get some 3M cavity wax in both sides for the final seal of approval  Grin    Comes with one very long tube and 360 degree nozzle
Also started to clean up the inner rear guard like I did on the other side.
now cleaned ready for a paint and to make a patch
Also picked up some parts
1. LOKAR Column shift kit
2. Speed Spares FC Grill badge  LINK> Speed Spare FC grill Badge
« Reply #339 on: January 29, 2021, 03:17:13 PM »
Great work Cam.
Badge looks good. Bit cheaper than an original one!
Clay
Pages: 1 ... 15 16 [17] 18 19   Go Up
Page created in 0.024 seconds with 16 queries.
