July 17, 2025, 05:03:44 AM *
Pages: 1 ... 5 6 [7] 8 9 ... 19   Go Down
Author Topic: Cams FC Resto  (Read 195259 times)
Ole
« Reply #120 on: March 26, 2017, 07:34:53 PM »
Neil, in my car with the XY tank and the standard fuel filler position, the fuel used to piss out on acceleration especially if you had more than half a tank of fuel. If you check out the XY tank you'll notice that the top half of the tank sits a lot higher than the boot floor, that is so that it can accommodate the spare wheel recess. I'm only relaying my experience and I am sure that if Cam mounts the tank in the same fashion so that it doesn't sit too low, he will have the same problem.
Adelaide SA
camxsmith
« Reply #121 on: March 26, 2017, 10:02:42 PM »
I can see some differences in the fuel filler height between the FC and XY. I might have to see what I can do to raise the input point.   Great Info and pointing out guys, appreciate the comments and help   Wink
XY        FC
Just looking at the filler hole I have cut out . It going to make it hard with the cars side beading at the bottom of the filler hole to raise it up.   I might have to use the top of two filler holes to make one nice filler impression to raise it up to the flat part of the rear quarter .   Have to check badge heights next... Shocked
GMHwagoon
« Reply #122 on: March 27, 2017, 06:27:31 AM »
  cam
 would it be easier to stay original  and just put a baffle in the neck to stop back flow
 l can remember the baffles at the top of the necks when you push the nozzle in it opens up
   just a thought
                             greg (fcwagoon)
camxsmith
« Reply #123 on: March 29, 2017, 12:05:21 PM »
Well shes home with her wounds showing, Nothing really that I did not already know about So im really happy..   Grin
Lots of good bits
Some fly wire in the floor..  thanks god for replacement floor pannels
K Frame has more to replace then I like, but its nothing I can not fix.
« Reply #124 on: March 30, 2017, 12:08:46 PM »
Cam I've just done the same thing with my FB/EK ute project and it lets you see all the good and bad, money well spent I thought.
Neil H
camxsmith
« Reply #125 on: March 30, 2017, 12:52:15 PM »
Agree Neil,  If I do it right, I hope not to have any rusty surprises later down the track.
camxsmith
« Reply #126 on: April 16, 2017, 12:52:18 PM »
Started on cutting and welding yesterday on the passenger side lower A Pillar.  Happy with the end result  Grin   Will now look at the out section of the pillar
First cut out the inner section
Made new section
Welded in with the cross member
camxsmith
« Reply #127 on: May 28, 2017, 08:27:08 PM »
Well got on the driver side sill on , but still have small amount of work to do in the rear dog leg and then compete the B Pillar. Which has some trick shapes. Undecided
Put some supports in before any cutting and welding
Remove all paint and prep with the KBS wash and rust blast
It got some KBS paint on the back and on the inner sill before assembly  and I will make a long paint brush and put on a third coat  as I sill have the small section open behind the dog leg.
Welded in place
Now all I have to do is the other side, This is one very lengthy process. I just hope I got all that rust because i do not want to do that again. Tongue
« Reply #128 on: May 28, 2017, 08:49:05 PM »
That looks great Cam, you've done a terrific job of the inner sill shape at the A pillar. For you can do that shape you can do anything  Smiley
Make sure you weld that end on the back of the sill at the C pillar when you've finished putting paint in!
Regards.  Ken
camxsmith
« Reply #129 on: May 29, 2017, 08:47:50 PM »
Thanks Ken means a lot coming from you. Im sure your done your fare share of cars and sills.
camxsmith
« Reply #130 on: June 11, 2017, 09:51:42 AM »
HI All still just slowly moving along with the build. Purchased a 7 inch dual brake booster and a KBS fuel tank kit for the XB fuel tank I want to put in.
All cutting and welding is currently been on the drivers side of the car.
Bottom of the B pillar , and holly shit Im glad there is only two of these. There is just so many curves and angles  Shocked  The passenger side is not as bad so hopefully not a full rebuild.
    (finished B Pillar images are coming IMGUR is having issues at the moment, will post next time)
Cut out and prep the drive side floor ready for some KBS and weld thru primer, would be nice to get at least one floor panel in on these long weekend.  Grin
« Reply #131 on: June 11, 2017, 10:59:14 AM »
Slow & tedious work Cam but it leaves no questions about the integrity of these sections now & later.
I think that's very important for your own peace of mind. It's a terrific job.
camxsmith
« Reply #132 on: June 11, 2017, 02:39:06 PM »
Thanks Dave and you are right it is a great peace of mind. Its funny but is also amazing to really see how these cars went together in the day. You real don't ever take the time in looking how they are constructed.
The missing B pillar images
« Reply #133 on: June 11, 2017, 03:06:14 PM »
Very thorough looking work there Cam. I have a pretty good pair of the b pillars from an FB parts car I intend to use on my ek van. The problem is all the double and triple panels in the a and b pillars always seem to be rusty inside at the bottom. Looks like your leaving nought to chance.
Clay
JOX515
« Reply #134 on: June 11, 2017, 06:07:43 PM »
Great work there Cam, car is coming along nicely  Smiley Smiley Smiley
camxsmith
« Reply #135 on: June 12, 2017, 11:13:25 AM »
Thanks Graeme and Clay
Worked on the the section in front of the rear wheel well. Thought I would coat the inner front section thats right blow it while i have its top off.
Every thing got a coat of KBS rust blast,  Not sure going to have a hot enough day to get any paint on there.  Have the heaters on flat out trying to get some temp up. Fingers crossed.
Front floor section bared where welding required and a coat of weld through and some holes for welds ready to go in.
« Reply #136 on: June 12, 2017, 11:17:13 AM »
Good stuff Cam.
Wayne b
camxsmith
« Reply #137 on: July 19, 2017, 08:12:53 PM »
Hi All
Had a play around with the mounting of the new dual 7 inch booster.
Looking at cutting out and replacing the fire wall section where the old brake and clutch cylinders were
Started by marking old and new locations on new backing plate.  Then removing old plate
Will move the brake peddle to the middle of the old housing.
Happy with how it looks so far.  Will make bushes for the housing and lathe the pin shorter and to have the new grooves for the location clips on either end.  Also make a new brake switch and rubber stopper mount.   So more to come on the booster.
Have the driver side floor in.  Just realised I have no picture of that . And have the rear floor prep ed and ready to go in. I have not started that as I need to put the seat belt plate in the lower B pillar while I have it open.
Got some 3mm plate and nuts to make the plates. Once the plates in I will close up the B pillar and weld in the rear floor panel.
I have a few seat belt question so will ask them in one of the already opened seat belt threads.
I also got a floor tunnel from the rod shop, which Im way off putting in.
So thats a bit of an update.   Grin Grin  Still loving every minute on the FC...
camxsmith
« Reply #138 on: July 22, 2017, 10:21:04 PM »
Just working on the new booster and pedal combo today
front driver floor
Boost plate cut out, bushed out the pedal either side on pin and  bump stop and brake switch housing altered for new location.
Have to cut down the main pin to size, cleaning up some welds, blast and then coat of paint. And we should be complete
camxsmith
« Reply #139 on: July 25, 2017, 08:02:55 PM »
Lathed pin down
Pages: 1 ... 5 6 [7] 8 9 ... 19   Go Up
Page created in 0.061 seconds with 17 queries.
