August 30, 2025, 02:07:24 PM *
Author Topic: Sump Removal  (Read 3559 times)
graham_fuller
« on: June 28, 2003, 01:27:20 AM »
Can  a grey motor sump be removed with the Motor still in the car?How easy is it.Could dents be filled with body filler without the risk of it falling off?
« Reply #1 on: June 28, 2003, 02:42:00 AM »
Graham,
Body filler, like paint, should be applied to a correctly prepared surface. With filler, you should remove as much of the dent as possible by hammering etc, then sand off all the old paint to around 2" outside the edges of the dent using 40 or 80 grit. Using a good quality body filler, apply as thinly as possible following the manufacturers instructions and then sand, prime and paint as normal.
If then dent hasn't creased the metal you should think about one of the dent removal companies. From what I've heard they do a good job and don't cost the earth, and you don't need any filler or paint!
ChrisB
"Shiny Bits"
« Reply #2 on: June 28, 2003, 09:38:21 AM »
Hi Graham,
re the dent as Craig said, the dent removal companies do a great job. My panel beater mate works for the NRMA and showed me the job they did on his new falcon as a demo. They had some serious dents in the rear quarter. I could not pick it, visually or with feeling it either. Only good if paint not damaged though
I was impressed !
Cheers ChrisB  Cool
« Reply #3 on: June 28, 2003, 11:26:31 PM »
Graham sump cant be removed with engine in car - well not unless you take off the front crossmember that is.
A dent in the sump can be repaired just like any normal dent, the heat of the oil wont affect it if it is done properly.
FCwagon
« Reply #4 on: July 02, 2003, 01:58:41 AM »
Hate to disagree with you Ken but the sump will come off with engine in. Steering drag link dropped, engine mounts undone and engine jacked up, bottom flywheel tinware removed and possibly the oil pickup undone and bingo.
You'll probably remember I took mine off in the caravan park at the Mildura Nats to check out the spun big end.
cheers,
Leigh
Red & white is alright
graham_fuller
« Reply #5 on: July 02, 2003, 02:13:55 AM »
Thanks Leigh.
Graham Wink
« Reply #6 on: July 05, 2003, 06:46:05 AM »
I stand corrected, Thanks Leigh
