August 30, 2025, 02:10:01 PM *
Author Topic: small oil leak  (Read 2266 times)
yackboy49
EARLY HOLDEN CAR CLUB INC. WANGARATTA
« on: June 20, 2003, 09:16:10 AM »
Just need some advice on oil coming from fly wheel cover, after a days running it drops a small amount.
how serious is this, &  does it get  worse ?
yb.
Phil
hkmonaro_68
« Reply #1 on: June 20, 2003, 09:53:37 AM »
 Poss coming out of the rear main seal, or from the sump. Make sure its not running down from the top of the motor first.
ChrisB
"Shiny Bits"
« Reply #2 on: June 21, 2003, 09:58:35 AM »
YB,
I would be checking all obvious places for leaks like rear of rocker cover and side plate first just to make sure its not coming from another spot first.
The rear main seal was discussed recently by another fellow who replaced it in the car. It was bad enough doing it on the engine stand where I could use a broken crankshaft to seat the seal and clean up the edges where the caps joined.
If it is the rear main seal and you can live with it I would wait until you had to pull the motor out before fixing it.
Cheers ChrisB  Cool
Page created in 0.057 seconds with 16 queries.
