August 05, 2025, 05:41:40 AM *
Author Topic: alot of smoke out of exhaust  (Read 2708 times)
dianne
Dianne Hyland
« on: May 26, 2013, 11:36:33 AM »
hi
i have 1959 fc and i found that there is alot of smoke coming out of the exhaust , so much it looks like fog, it looks grey or slighly blue, i changed the modulator but im not sure if the one i put in is also faulty. Can anyone help with this one?
colt
act-club
« Reply #1 on: May 26, 2013, 11:48:35 AM »
Modulator? Do you mean PCV valve? If so, FC's aren't fitted with one, they are usually fitted after market. All greys have natural breathing thru the walking stick. I'm assuming you have a grey motor? You may have another more major issue.
Colin.
colt
« Reply #2 on: May 26, 2013, 02:22:55 PM »
Bluish smoke is a sure sign of burning oil which comes from only one of two places.
The first is past the valves, the other is past the rings. Get a wet and dry compression test done and this will tell you where the problem is.
« Reply #3 on: May 27, 2013, 03:46:19 PM »
Bluish smoke that stinks could be oil - rings, valve guides or a PCV that is getting overfed (e.g. lack of baffling... assuming this thing has a PCV in the first place).
Whitish smoke that stinks could be transmission fluid (assuming this thing has an auto gearbox with a vacuum modulator).
Whitish smoke that doesn't stink and condenses could be a badly blown head gasket.
Ken right - start with a wet and dry compression check.
