August 11, 2025, 02:59:52 AM *
Author Topic: window regulator for drivers door  (Read 1558 times)
surferboy
10,000 POINTS !
« on: November 22, 2012, 11:49:03 PM »
Looking for replacement window winding regulator to fit drivers door
I've worn out another one  Roll Eyes
The teeth are razor sharp pointy things and keep slipping and jamming so you can't move the window. Angry I've resorted to driving my wagon around with the door panel off so I can juggle bits around to move the window !
Is it possible to modify the regulators from any of the other doors  Huh
If it is.. could somebody post instructions (with pictures would be good ) as I would have to get someone else to do the modification for me (unless you can do it with one bent screwdriver and a hammer with a loose head...  I'm not much of a DIY type )
I have replaced the drivers door unit 3 times now. But using 2nd hand ones, they really don't last very long on my daily driver.
Does anybody produce a replacement one
Or can a new one from a different model car be used ?
Ta
surferboy
 Cool Cool Cool
cruisin's great with a 58
« Reply #1 on: November 23, 2012, 05:35:34 AM »
New runners and felt strips put major strain on the old winders.
I would not think there is a stronger unit than an old holden unit.
Some have done electric conversions but I think they too will start breaking teeth ect.
Why not pull one apart From a rear door and either make the arm longer or try get the gears from a rear as most have had a lot less use.
Also your channel alignments are a major contributing part I read the manual to help me work on getting it to slide up the channel smooth without a winder installed.
I used a piece of 3mm plastic and a hammer tapping the plastic into the channel to make sure the Bailey channels were set in properly.
I also used lynx deodorant with 'graphite' I know it sounds silly but as mentioned elsewhere this stuffs great for locks ect as well it goes on dry and lubricates.
Good luck
Pete
