July 25, 2025, 02:02:25 PM *
Author Topic: Repro outer Sills  (Read 6001 times)
FC_NUT
« on: June 19, 2012, 11:33:03 PM »
Hi all,
Could anyone confirm for me the best reproduction outer sills on the market?Huh
The guy from Queensland (Craig) I hear has great sharp profile, not concerned about the ends.
Not interested in any Rares Items either.
Any info would be much appreciated
Daimien
Daimien,
Carrum Victoria
Ole
« Reply #1 on: June 20, 2012, 08:23:51 AM »
Hi Daimien,
I used Craig Vane's sill panels and found them to be of good quality. The profile was accurate and the guage of the metal was good. My only concern was that one panel was slightly larger than the other. When they arrived packaged up one sill fitted neatly over the other so it was a couple of mm's larger than the other. It created a bit more work to fit but it wasn't impossible to rectify. They were alot cheaper than Rare Spare's as well.
Adelaide SA
« Reply #2 on: June 20, 2012, 09:58:14 AM »
I'm currently fitting retro rods outer sills, I think they're a good product, and can be made to fit well.
I know you're not interested in the ends or Rare Spares product, however if you can find some Rare Spares repros it may be worthwhile as it takes a fair amount of effort to fabricate sill ends replicating the factory finish.
Any reproduction panel will require some degree of effort to make it blend in with factory lines.
Not Happy Jan
Aussie adventure
« Reply #3 on: June 20, 2012, 10:50:20 AM »
pictures please Ed
Nick
You can never have too many!
Port Macquarie NSW
fink fc
« Reply #4 on: June 20, 2012, 11:03:18 AM »
Put Craig Vane ones on my van  no probs,your welcome to come checkem out anytime.
« Reply #5 on: June 20, 2012, 12:06:59 PM »
Was just looking at the Craig Vane ones that are on the ute... The fabricator explained that because they are straight the front of the sill sits in slightly needing and adjustment at the door and the original sill has a constant curve that the repo's don't so basically you will have a straight edge to the end of the door and then will need to be shaped as the sill goes to the rear wheelwell. aal my photos are under 365 days.. if you want to see what i mean.
« Reply #6 on: June 20, 2012, 02:01:10 PM »
here are some retro rods sills fitted to an FB I prepared earlier.  Haven't got any pics of the current job, but it is the same panel supplier.
the "curvature" is obtained how JB describes, leaving parts of the old sill as reference points allows you to get it as close as possible.
hope this helps.
FC_NUT
« Reply #7 on: June 21, 2012, 01:04:22 AM »
Thanks guy's,
As usual a great response to my question and a lot of help.
Daimien,
Carrum Victoria
