May 24, 2025, 11:21:38 AM *
Author Topic: Muncie clutch setup  (Read 3107 times)
2door350
RAT 059
« on: April 28, 2012, 04:03:35 PM »
Hi,
Trying to setup my new Autogear M22 on the desk before it goes in my HT on Monday, Ordered a Hadfield hydraulic slave bracket CB03 which arrived last night, dummy it up on the bellhousing (factory 10.5" chev passenger side fork entry with factory clutch fork) and the angles are all wrong!
Looks to me that it doesnt work with the factory fork? Rodshop told me it will when i ordered it, rang them yesterday arvo, apparently their 'expert' is away till monday lunchtime...
Got car booked in my mates workshop first thing monday morning to swap in my new 350 and muncie for old 350 and t400, Need a solution?
Anyone got a pic of thier hydraulic muncie clutch setup?
2ddor350
brett_f
« Reply #1 on: April 29, 2012, 11:59:11 AM »
2door350,
Are you running the original chev bellhousing. I used the muncie in an LJ torana and simply hooked up the original rat trap clutch. The chev bellhousing has the mount for the pivot ball on the rh side but is not drilled or tapped. It also has the hole for the fork but just needs to be cut out. If you end up going down this path let me know as i still have the tap for it.
Regards Brett
2door350
RAT 059
« Reply #2 on: April 30, 2012, 10:50:26 PM »
It was an auto so no rat trap, think i've got it sorted now, cut up a fork and made it happen Wink
Page created in 0.029 seconds with 18 queries.
