August 15, 2025, 01:08:51 AM *
Author Topic: f.c.discs  (Read 3747 times)
fcee
« on: May 08, 2011, 09:59:49 AM »
 :)Thinking of fitting l.h torana discs to my standard f.c front end with the aid of a bracket kit ,would my existing vh 24 booster be suitable to use with this set up ,like to retain the v.h 24 if possible ,comments please Smiley ,Steve
Sale Victioria
« Reply #1 on: May 08, 2011, 02:57:25 PM »
Not really - The VH 24 is a drum brake booster - it doesn't put out enough grunt for discs
Paul In Ireland
« Reply #2 on: May 08, 2011, 06:16:18 PM »
Well, you could always leave the booster there for looks if you like it - its your car.
fcee
« Reply #3 on: May 10, 2011, 06:38:10 PM »
 Thanks Ken for  the sensible answer ,think I will stay with the drum brakes  .  Steve . Smiley
Sale Victioria
Glen
« Reply #4 on: May 29, 2011, 06:15:21 PM »
My FC has the VH24 booster with LH front discs on HR ball joint front crossmember, and HR rear brakes with 9/16 cylinders. (important)
The brakes are excellent. The VH24 was the standard booster on  the HR with disc brakes.
Dr_Terry
« Reply #5 on: June 01, 2011, 07:43:56 PM »
Glen, that's not quite correct.
As Ken has said the VH24 was a drum brake booster & these ceased production around 1963/64. The similarly-sized VH44 replaced it but this was still a drum brake booster. HD & 1966 HR disc braked cars from the factory used a Girling 5/8 booster & this was superseded in early 1967 by the VH40 booster. The VH40 looks similar to the VH44 but has a larger diameter 'diaphragm' section. The old VH24 had an all-alloy construction.
The VH40 is the booster of choice for old Holdens with disc brakes & a single hydraulic system.
Dr Terry
Glen
« Reply #6 on: June 03, 2011, 09:57:32 PM »
My apologies for that, I was trying to pull figures out of my head from 30 years ago when I bought mine as a stock item from a holden dealer.
Page created in 0.019 seconds with 16 queries.
